A20 LEE
Recaro Wiring Loom
Seeking abit of advise from the recaro experts among us. I've got my new Recaro SR's in on factory recaro subframes but i haven't got the looms. Are this available from the dealers? Were does the loom plug into? Is there a connector under the carpet or does the loom go to the fuse box?
TIA
when i priced a loom for my heated recaros at the dealers they were well over £100 :shock:
For the pair or each?
i think it came all in one for the heated seat loom,i ended up paying £15 for a 2nd hand loom which i still havent fitted yet
Will a golf loom work? My seats aren't heated.
oh right,if its just for the tilt and the up and down then you can make your own,there was only 2 wires on mine,one live and the other earth
Lee, if you're after just the electric adjustment make up your own loom. All you need is a live (fused of course) and an earth. If you remember the Recaros I had in my Mk1, I wired these up making up my own loom and it worked perfectly.
cheers guys.
Thought about making my own loom as a tempory measure (i'm currently using a battery charge to adjust them). I'd like vw loom once the money situation improves. Where do i connect the the loom too? Fuse box?
