dgrt 0 Posted August 25, 2004 I was coming up a hill after a long run and noticed some blue smoke, after coming over the brow heard a horrible noise and the car stalls. Pulled over and had a look and the grooved altenator belt was in 1000 shreds. The car is being towed to a garage to be inspected tommorrow. Does anyone have any experience and would know where to look first for the cause.. thanks Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted August 25, 2004 could be a failure of the tensioner/seizure of the tensioner pulley bearing. Quote Share this post Link to post Share on other sites
dgrt 0 Posted August 25, 2004 Could this affect the timing chain as it was running like a bag of spanners when I stateted the engine after pulling over. Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted August 25, 2004 Woundn't have thought so as the chains are on the right hand side of the engine although the fact that the pumps weren't working might affect how the engine runs. Quote Share this post Link to post Share on other sites
dgrt 0 Posted August 25, 2004 many thanks - apoloigies for my ignorance but what does this belt drive apart from the alternator? Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted August 25, 2004 power steering pump, water pump and air con if you have it fitted. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted August 25, 2004 Woundn't have thought so as the chains are on the right hand side of the engine although the fact that the pumps weren't working might affect how the engine runs. ah but if the ferocity of it siezing/jamming/breaking etc was strong would it not perhaps made it jump a tooth or worse :shock: out timing wise :?: Quote Share this post Link to post Share on other sites
dgrt 0 Posted August 26, 2004 It appears that the belt tensioner pulley has seized. The garage is installing a new belt etc. today. I don't know what the blue smoke was though? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 26, 2004 Blue smoke? Probably the old belt melting... You don't wanna drive around without your water pump working, so it's a good thing the engine stopped I'd say! BTW - how much was the new tensioner? The belt is £28+VAT (£18 with discounts). Quote Share this post Link to post Share on other sites
markiemark 0 Posted August 26, 2004 Same happened to minee when the water pump died. Blue smoke was from the belt rubbing on the seized pump :( Quote Share this post Link to post Share on other sites
dgrt 0 Posted August 26, 2004 i've no idea how much the tensioner will be - VW part only - Will let you know when I get the bill !! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 26, 2004 Reason I ask is I have heard recently that someone got one for £60 + VAT, which is less than HALF what we were expecting to hear, so it'll be interesting to hear from you. Quote Share this post Link to post Share on other sites
markiemark 0 Posted August 27, 2004 When I had mine replaced about a year ago it was £80 +VAT, which I was pleasantly surprised at 8) Quote Share this post Link to post Share on other sites
dgrt 0 Posted September 15, 2004 Total bill for new belt, pulley and something else and recovery was £180. It seems however that the crank seal was disturbed by the shredding so replacing this will be extra. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted September 15, 2004 And how much was the pulley itself? Quote Share this post Link to post Share on other sites
dgrt 0 Posted September 16, 2004 pulley £60 , Belt £28, Breather pipe Hose £14 rest was labour VAT etc. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted September 16, 2004 cant you just replace the bearings in the belt tensioner pulley ?? i'm sure they are just skf bearings ? did you notice any signs of this going before it went , was it noisy at all , i mean like weeks before ? you would expect the bearings to make a noise to give you warning Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted September 19, 2004 I can do a rebuilt tensioner with a new bearing for £30 exchange. thing is, your pulley will probably be f*cked now, so I'd have to see it before I could accept it/ Quote Share this post Link to post Share on other sites
dgrt 0 Posted September 21, 2004 No warning - but then again if I hear a funny noise I usually just turn the radio up. Quote Share this post Link to post Share on other sites
