kvwloon 0 Posted August 25, 2004 ...bought a second hand Perma Cool sandwich oil-cooler, hose and rad. set up from a guy at North Weald Volksfest, but missing the 'O' ring for the sandwich plate. No problem I thought, he only wants £25 the lot, and can get a seal locally easily. However, after trawling round motor factors coudn't find anything close enough to fit, and was just beginning to think I'd been sold a pup. However, quick search on Net and e-mail to Perma Cool, result, theyr'e posting me a couple of seals free of charge from USA! I'm impressed. Thought i'd give them a quick 'plug' on here as a result. 8) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted August 25, 2004 now thats what you call customer service!! :D Quote Share this post Link to post Share on other sites
kvwloon 0 Posted August 25, 2004 Yep, and I didn't even ask for the seals, only where I could get them in UK. Mind you, I did kind of hint by putting my full address at the bottom of my question! :lol: Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted August 27, 2004 so have you now fitted this oil cooler,and if so did it make much differance to oil temps Quote Share this post Link to post Share on other sites
kvwloon 0 Posted August 27, 2004 Not yet, just waiting for the seals to arrive and then a bit of time spare, and will give it a bash. I would say it would 100% definately cool the oil better though, must be better than running hot water through the oil cooler to do the job! I'll advise as soon as I do it and see the results. Am sure it wil give same result as the Mocal coolers others on this Forum have fitted already.....perhaps they can comment too......I'm estimating at least a 10 celcius drop across the range. Quote Share this post Link to post Share on other sites
yellowslc 0 Posted August 28, 2004 Did that kit come with a thermostatically controlled sandwich plate? That is a definite plus in cold weather climates. Quote Share this post Link to post Share on other sites
kvwloon 0 Posted August 28, 2004 yellowslc, I kind of think so, there is a spring loaded valve built in, but not sure if / how that would be thermostatic, might be, might not be, but I hope so. I think it will be as Perma Cool does seem to be a good brand from what I can find out. Quote Share this post Link to post Share on other sites
yellowslc 0 Posted August 29, 2004 Ok you have the one a friend of mine was using. There is a thermostat per say in there.. think home furnace sprial spring.. they work. :) Quote Share this post Link to post Share on other sites
kvwloon 0 Posted August 30, 2004 yellowslc, That's nice to know, many thanks! Quote Share this post Link to post Share on other sites
