sefton 0 Posted December 23, 2002 Hi I've just ordered some new wheels! Do I have to have anything done once they have been fitted like traking etc? Regards Sefton. :?: Quote Share this post Link to post Share on other sites
dan 0 Posted December 23, 2002 Hi sefton, You should only need to get them balanced and aligned. Whoever fits them should be able to do that in 5 mins. The tracking only needs to be adjusted if you lower the car. what kind of wheels did you buy? Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted December 23, 2002 If your tracking hasn't been done in a while, and you're going up in size, i.e. from 15s to 17s, you might wanna think about getting a full 4-wheel alignment done at some point. Larger wheels have a greater tendancy to tram-line and pull you about more if out of line, so worth making your car easier to drive and reducing tyre wear. If you're staying the same size (or going smaller? :shock:) then just the balancing they'll do when they put the new tyres on will be fine. Enjoy - and don't forget some piccies for the Gallery section :) Before and after :?: :D Quote Share this post Link to post Share on other sites
sefton 0 Posted December 23, 2002 I have orderd some 7.5x16" Brock B2 with polished dish! oh yeah the off set on the rear is lower than the front! How much will a garage charge for a full wheel alignment? I will send some pics once Ive got them on!(I have to figer how to post them on the members gallery)! Quote Share this post Link to post Share on other sites
W3RKD 0 Posted December 23, 2002 DONT GET RIPPED OFF you cant adjust the rear wheel alignment so dont let anyone charge you for 4 wheel alignment, just the front! Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted December 23, 2002 Sorry, I'm used to having a car with full camber / castor / angles / tow setup... :) Camber on my front left is right out. Need to get that sorted at some point... Ah the list :shock: Quote Share this post Link to post Share on other sites
