fast x
Vr6 ht leads which ones?
Hi guys which Ht leads would u guys recomend for a vr6???
i hear the blue ignitiers are very good???
anymore suggestions will be apresiated. thanks
philip.
I'm sure someone had found a source for OE Beru red leads for not much more than a tenner a lead - i.e. about £60-70 the set...
Are the G60 Beru's red as well?
Been thinking about some red leads to just add a bit of colour under the bonnet! :)
Hmm. My Local Ford garage says
HT leads 1/2 are £18.49 each
others are £16.25 each ..
which makes a lot more than the £70 or so other people have been quoted.
They also quote £86.84 for the aux belt tensioner, so it sounds like even VW are cheaper!
And having spoken to AVS the set for £58.13 is for distributor cars. The later cars have very slightly shorter leads (just a couple of cms each) and different ends - they have all-metal ends, rather than the metal/rubber combo on early cars. Hence a higher price: £67.82.
Note these are not RED - they will be black leads, as far as the guy can tell me.
Magnecor HT Leads
7mm Leads: Black in colour & direct replacement for 7mm original equipment carbon conductor leads with excellent RFI and EMI suppression. Overcomes problems associated with limited-life carbon conductors and poorly suppressed aftermarket spiral conductor leads on modern engines.
8mm Leads: Blue in colour & original equipment replacement. Designed to improve original ignition system performance on road vehicles using either electronic engine management systems or carburetors.
8.5mm Leads: Red in colour & primarily designed for racing engines using racing ignitions, turbocharging and supercharging. Entire jacket made from aerospace extreme heat-resistant silicone rubber. Exclusive Magnecor 2.5mm Metallic Inductance Suppressed Conductor will suppress EMI indefinitely, allowing this cable to be used on road vehicles with any ignition.
Title Awesome Part # Price
Corrado 16v Magnecor 7mm Leads EN-HT-GO2-MAG4 £95
Corrado 16v Magnecor 8mm Leads EN-HT-GO2-MAG5 £95
Corrado 16v Magnecor 8.5mm Leads EN-HT-GO2-MAG6 £105
VR6 Pre 95 Magnecor 7mm Leads EN-HT-VR6-MAG1 £85
VR6 Pre 95 Magnecor 8mm Leads EN-HT-VR6-MAG2 £85
VR6 Pre 95 Magnecor 8.5mm Leads EN-HT-VR6-MAG3 £105
VR6 95-> Magnecor 7mm Leads EN-HT-VR6-MAG4 £75
VR6 95-> Magnecor 8mm Leads EN-HT-VR6-MAG5 £75
VR6 95-> Magnecor 8.5mm Leads EN-HT-VR6-MAG6 £95
there from awesome gti,i think you have to add vat on top of the prices
