craigbeal
power stearing belt
Belt is screeching when im reverse parking and at full lock now so i asume the belt need tightening or replacing?? how do i go about tightening the belt?
If its like mine then there is a 13mm bolt underneath the front of the car that tensions the belt between the pump and the bracket, check the belt for condition, replace if cracked and spray some silicon belt dressing if its still screeching
you also need to undo the mounting bolts on the pivot for the P/S pump else it won't move as you adjust the tensioner and you'll end up breaking something... There's a hidden bolt inside the mounting which you get at from the nearside of the mounting... have a GOOD look around under there to try and work out how it all pivots, and you'll see what I mean... 8)
