DiElBramz
46 -
0 NeutralAbout DiElBramz
- Birthday 09/06/1987
DiElBramz started following 1.8 16v idling problems. fuel injection system maybe?, Brake compensator, early "g" 1990 white 1.8 16v corrado breaking and and 5 others
Not seeing any on Ebay!! Can you link me??
Anybody got a brake compensator for my early 1.8 16V Rado? If not, any advice on what other cars I will find one on that will fit my car??
Breaking 91 .corrado early 16v NOW WITH FREE POSTAGE
DiElBramz replied to rodmax's topic in Cars for Breaking
Will the the load sensing valve/brake compensator get my car through its MOT? How much posted? Hope to hear from you very soon. -
DiElBramz replied to trevyt's topic in Cars for Breaking
Passenger window switch? And a wee bit for window, not sure what they are called, if they even have a name!! There should(?) be prehaps 2(?) small plastic(?) bits that go in the window channel and allow window to go up and down.... hope that description means something to you!!? Already got a mechanism to fit but there is something missing!!! ---------- Post added at 04:27 PM ---------- Previous post was at 04:26 PM ---------- Passenger window switch? And a wee bit for window, not sure what they are called, if they even have a name!! There should(?) be prehaps 2(?) small plastic(?) bits that go in the window channel and allow window to go up and down.... hope that description means something to you!!? Already got a mechanism to fit but there is something missing!!! -
Couple of bits I'm needing, if you've still got them!? Rear passenger side girling brake caliper? Passenger side window switch? And a wee bit for window, not sure what they are called. There should be 2(?) small plastic(?) bits that go in the window channel and allow window to go up and down.... hope that description means something to you!! Hope to hear from you soon with a price if all these parts are available!!
Ah super! Thanks for your advice!!
Needing a rear caliper for my 1989 16V Corrado, I know someone thats breaking a 1997 Gti Ibiza Cupra and reckons that the caliper will fit my car off it! Yeah or nae? If not, what VAGs (that are fairly common come across!!) will I be able to take one off fae??
Needing a passenger wheel hub for early valver (4 stud!!)
at my wits end with this money pit now!!! got an early 1.8 16v (kr engine) bought it about 10 months ago, didnt idle or run right when i first got it to be honest then stopped running altogether 6 months ago. its had new distribuator, ecu, ignition panel, coil package, been to an auto electrician who checked the wiring and timing, although he got it running the car still isnt idling well enough for an MOT. my dad thinks it could be something to do with the fuel injection system and wonders if this can be adjusted?? it runs poor at low revs but once heated up runs a little bit better!
- 1 reply
- fuel injecton system
- not idling
(and 1 more)
Tagged with:
Thanks so much!! Work on the car has been delayed with the struggle in finding diagrams!! Many thanks again!
Where can i find wiring diagrams for early 1.8 16V? What cars would be of same wiring?
COIL PACK is what has been ordered!!
had a search through the forum but nothing answers my question... my car been having idling problems, missing revs when running, gulping fuel, and smelling of fuel!! well the garage said ther was some wiring that needed to be sorted, he done that yesterday, well i call today and been told me car aint starting atall!! they have ordered a new spark(??) i think he said!! any other ideas what the prob could be?? starting to miss it :( and also running out of money and patience for the :censored: as its already been in garage for over a 6weeks getting work done!!
