badlad1888 0 Posted October 4, 2004 I have just bought my second rado, a g60 and it has two problems 1. with someone in the back off the car, when you put the foot down it sounds like a hammer hitting the underside off the car at the rear.i had a look but everything looks ok, any ideas! 2. when i change gear above 5000rpm i can hear a high pitch chirping noise is this normal! as you can guess i have no mechanical experience and need help!!!!! :oops: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 4, 2004 1) exhaust banging on rear axle. car been lowered? get the exhaust mounts looked at! 2) take the sparrows out from under the driver's seat!!! ;) Quote Share this post Link to post Share on other sites
badlad1888 0 Posted October 4, 2004 ok i will get that checked out asap about the exhaust. i am guessing the gasses escaping on the gear change is normal,i have owned the car a few weeks and never driven it hard until the weekend, then i heard the noise. :D got to show the clio sport boys who is boss!! Quote Share this post Link to post Share on other sites
ben16v 0 Posted October 4, 2004 hissing i`m thinking you`ve had the boost return mod done??? i`m no expert ....??? :oops: Quote Share this post Link to post Share on other sites
Jim 2 Posted October 4, 2004 The car hisses and whistles all the time when its had the boost return removed.. I think it must just be slightly tuned - every single G60 i've ever been in ALWAYS sounds different - you get all kinds of weird whistles, hisses, droans, etc etc depending on which car you go in! Mine makes a cool little whistle / dump valve kinda noise when you change up at quite high revs :D Quote Share this post Link to post Share on other sites
badlad1888 0 Posted October 5, 2004 the car has had some work done before i got it so there is a good chance, you guys could be right. thanks :D Quote Share this post Link to post Share on other sites
Storm 0 Posted October 5, 2004 Never enough room I find; and there always the risk of burning your arse on a hot zorst. :wink: Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted October 5, 2004 has it been lowered ? sounds like tyres rubbing the rims or mudflaps scraping the ground or weak exhaust hangers ( rubbers ) just the xtra weight in the back makes the differance. Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 5, 2004 Storm said: Never enough room I find; and there always the risk of burning your arse on a hot zorst. :wink: Note to self: Don't work on hot car :roll: :lol: Quote Share this post Link to post Share on other sites
VR6 0 Posted October 5, 2004 Quote Banging under car Be careful of gravel rash. Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 5, 2004 VR6 said: Quote Banging under car Be careful of gravel rash. :lol: I was gonna say let the body out of the boot, but that works too ;) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 5, 2004 VR6 said: Quote Banging under car Be careful of gravel rash. 9 useful/helpful replies to this and VR6 goes and lowers the tone of it :roll: :-P :-P :-P Quote Share this post Link to post Share on other sites
theRuler 0 Posted October 6, 2004 the banging sounds like the exhaust flapping about what are the engine mounts like? if the front one is slack, just a little rock in the engine can send the pipe nuts Quote Share this post Link to post Share on other sites
vwdubs 0 Posted October 6, 2004 Another noise that could be causing the banging is the handbrake cable not located properly Quote Share this post Link to post Share on other sites
badlad1888 0 Posted October 6, 2004 problem solved was under the car today it was the exhaust hitting the axle it is fixed now :D cheers Quote Share this post Link to post Share on other sites
