Tekara
Whats it going to cost
Hi All
My VR6 is in need of some serious work, bought on the cheap i knew it needed much of the working doing. Just wondering if anyone could put a rough figure to the cost of this.
Exhaust, Mid/Rear + Centre boxes
Brake disks rear
Shocks + Bumpstops rear
Brake pads all round
Rear wheel bearings
Replacement seals on oil cooler
Front engine mount (for safety's sake)
+ Labour Costs
Would try to get it done through a VW specialist, and im after all VAG parts ideally.
Vibratechnics front mount plus fitting about £170 incl VAT (I had this done - component from TSR. Local garage fitted for £15 plus VAT. )
all them jobs are easy to do,why not get your hands dirty and save yourself some cash..as the labour costs will be at least £200 or more
Yeah would try my hand at most things there. Only problem is the weather :( garage is too full to fit the car into and MOT is due soon.
Hi All
Brake disks rear
Rear wheel bearings
+ Labour Costs
tbh that little list is really just minor fettling................
exhaust IMO its best to get either a MIlltek or Magnex cat-back system....so budget approx £300-ish(£30-£50 fitting)
rear brake discs are approx £30-£50 a pair (1-2hr labour inc wheel bearing/pad fitting)
rear shocks and bumpstops will be approx £100 (2hours labour) GS+F or Euro-car-parts for them
rear wheel bearings approx £15 from VW a side
replacement seals for oil cooler are £2ea approx(30-45mins labour)
engne mount from VW is approx £50+vat.....vibratech one is £100+(15-30mins labour)
front pads £15-£25 depending on what pads you use (and approx 30mins a side)
you may as well change the abs rotor cages on the rear discs if you are getting the rear discs and bearings done......this will add approx £10 ea side to the price
Thanks for that VR6Storm. Yeah i suppose it is really minor in the grand scheme of Corrado ownership, just my first ever major outlay on a car in one sitting. Good tip on the "rotor cages" forgot about them, had problems with those on my last VR6. Will get those replaced too.
