Shilakadaddy 0 Posted December 28, 2004 I'm gonna buy some Konigsport coilovers for my G60 within the next couple of weeks, and was thinking that I should replace the various other bits of rubber etc. that affect the handling of the car (bushes, bump stops.. that kinda thing) at the same time. Then get it all properly set up :) Just wondering what bits there are to replace (front and back) and whether I should just replace these with OEM parts, or can I get uprated versions? I'm gonna be running the coilovers quite low so I wanna make sure I've got everything sorted so that this is possible. Cheers, Chris PS. Liking the new forum, good work Andi :lol: Quote Share this post Link to post Share on other sites
goodridge 0 Posted December 28, 2004 Depends how far you want to go really? I would say at minimum new top strut mounts-you can get uprated aftermarket ones if you wish. Or if you want to go the whole distance, you could fit poly bushes all the way through. Apparently they can be had fairly cheaply through GSF. It's just the fitting which can add up if you are unable to do the work yourself. Hope this helps Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted December 29, 2004 Stick to OEM rear bushes at the back as they dictate to a large extent the feel of the car. Quote Share this post Link to post Share on other sites
Bally 0 Posted December 29, 2004 I replaced all new top mounts etc, been ok for the last 20k, although I'm looking to replace all new rear bushes etc.. rides getting abit boucey now.. :roll: Quote Share this post Link to post Share on other sites
Shilakadaddy 0 Posted December 29, 2004 So all I need to get is OEM Bushes Aftermarket Top Mounts I remember reading I need some longer bolts for something if I'm going really low? - to adjust the rear camber or something like that?? :? After doing all this, I think I'll get my engine running sweetly too.. looking forward to 2005 :D Quote Share this post Link to post Share on other sites
Bally 0 Posted December 29, 2004 I havent heard of the longer bolt thing?? myns low never had any probs with the rear... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 Rear camber can be adjusted by shimming the stub axle. Which bolts need to be longer? Quote Share this post Link to post Share on other sites
Shilakadaddy 0 Posted December 29, 2004 I can't find what I'm talking about... I just remember reading something about needing longer bolts for something to do with lowering... It seemed to be common knowledge so is probably totally unrelated :oops: Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted December 29, 2004 The bolts that clamp the strut to the front upright on a VR6 (and presumably all late-model cars) allow the camber to be adjusted. The bolts fitted to early 4-stud cars don't allow any adjustment. It's not really a problem unless you're planning on a stupidly low ride-height. In which case the handling will be so bad anyway, there's no point in worrying... Quote Share this post Link to post Share on other sites
Henny 0 Posted December 30, 2004 I know that John (16VG60) advises using the later camber adjuster bolts when you lower a corrado to ensure that the camber can be set spot on to your requirements.... I had a set on J-DUB and without them wouldn't have been able to run the camber I ran with.... ;) Quote Share this post Link to post Share on other sites
