Dancing Fish
Fitting Side Repeaters
side repeaters are removed by pulling back and pulling leading edge out. They only clip in and aren't glued as you'd have trouble changing bulbs!!!
Watch out, I removed mine and the small tab that holds them in broke....on both repeaters.
Luckily I was fitting news ones anyway.
/Waits for thread:
"How do I get back my side repeater leads from inside the wing?"
take off the plastic arch liner and than try and feed it through :D been there seen that etc etc make sure next time u mask it to the outside jus in case
wire coat hanger bend end into hook stick through hole spend half hour "fishing, hook it pull it, job done. :mad: :)
If you do get no standard repeaters you can just stick tehm on with some cushioned double sided all around the edge. Just make sure the paint is properly cleaned. That s plenty strong enough to hold them but not too harsh that when you need to change the bulbs half the paint comes off.
