timg60 0 Posted December 2, 2005 Looking good, Black is the way forward. If yo are after a Airbox with no holes in it I have one that I could part with. Tim Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 thanks mate - no got a 'hole-less' airbox - just i think that with the combination of a k&n and no snorkel is very very loud. its only been this loud since i got rid of the airbox that had holes in it.... Quote Share this post Link to post Share on other sites
Joe M 0 Posted December 2, 2005 ooh, theres a pic of me on the forum now. :oops: _leon_ said: one thing I noticed now getting an airbox that someone has drilled out holes in - with a n&n and the snorkel removed the noise is deafening. would i std panel filter from VW cure this? And is decent enough to use? What else would be suggested? I reckin you would deffo need an undrilled box, the filter itself doesnt make a huge difference to noise. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 damn it i must have been exhausted when i posted last night! i meant that since i have replaced a drilled out box with an undrilled out box, the noise has been immense. Its easy to tell its coming from the airbox - you can locate the 'roar' just by standing in front and yanking on the throttle cable! Its too much for an old cobbler like me ;) and want things a little quieter... yep youre now famous mate :) Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 2, 2005 Replace the snorkel. There is great big hole in the front of the airbox that the air is being inducted through if its not there. I found the same with mine and that a sensibly drilled airbox with snorkel in place was more subtle. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted December 2, 2005 Looks great, similar ride height to mine on the same wheels. :) Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 coullstar Yes I should try and find a snorkel then to see if thats helps - at the moment the noice is ridiculous. Neil G60 Thanks mate :) I do like the standards yeah - they look great when the car is all clean. But I would eventually like other wheels - I really like the 16" Keskins that Furki on here and also the 15" Schmidt Modernlines G-Lader used to have on his. I would be also be happy with some RX2's! lol Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 2, 2005 I think an 8v golf uses the same snorkel. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 good idea mate. Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 2, 2005 I changed that last post as the car would then have no way of inducting air. Blonde moment. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 i took it that you'd reduce the hole - not cover it 100% ;) what do these snorkels look like anyway? never seen one Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 2, 2005 Nah, the snorkel actually supresses the noise so it probably wont work. go here - http://www.kf010a4571.pwp.blueyonder.co.uk/ Airbox drilling is in the downloads section. Picture two shows the snorkel tube. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 2, 2005 ahh thanks for that. Yes I definately don't have that snorkel. Interesting to read about the drilled airbox - tbh I haven't noticed any difference going from the drilled to undrilled. I'll be sorting the cold air feed through the carbon cannister hole this xmas anyway. coullstar help appreciated mate. where in bonnie scotland are you? Quote Share this post Link to post Share on other sites
coullstar 0 Posted December 3, 2005 Aberdeen, used to live in Kirriemuir. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 3, 2005 was close by there earlier today - on the way to glenshee. Quote Share this post Link to post Share on other sites
Furkz 0 Posted December 28, 2005 cant forget the days mine looked like that...so standard Quote Share this post Link to post Share on other sites
_leon_ 0 Posted December 29, 2005 if i didnt plan to put bigger brakes on it - therefore needing different wheels, then it would stay that way (with the exception of the grill) - i like it looking that way :) but the std bbs' are a pain in the a$$ to keep clean. bring on the comp2s... Quote Share this post Link to post Share on other sites
_leon_ 0 Posted February 16, 2007 Lots of work has happened since and I made a list of work done to it since buying 2 years ago... 1991 Metallic Black Corrado G60 154k miles FSH and huge folder of receipts and documentation All MOT certificates Engine and Chassis Engine and gearbox replaced at 52k miles (VAG documented) Jabbasport Big Valve head 285 piper cam Schrick vernier pulley Bosche WD5PO plugs New HT leads G-werks standard rebuild on charger 8k miles ago (been inspected since and perfect) New supercharger oil pipes K&N panel filter All new belts including cam belt, tensioner Rocker cover powdercoated matt black Inlet manifold port matched to head and powdercoated matt black, wrapped in cool tape Vibratechnics fast road front engine mount New OEM rear mounts Redline MT90 gearbox fluid Bosche Silver battery Supersprint 4-2-1 manifold Supersprint full cat back system Polyflex exhaust bungees New Bosche Lambda MKIV rear calipers with goodridge lines New rear disks New wheel bearings all round New front wishbones All bushes replaced with OEM items New brake lines New clutch slave cyclinder Carbon canister removed and associated pipework RSR outlet Boost return removal kit Catch tank New temperature sensors New steering rack, track rods, ball joints Zimmerman Front disks Pagid fast road pads all round Replacement starter motor New Bosche alternator New Knock sensor Low temp fan switch Low temp thermostat New inner and outer CV joints (all) New distributor New crank shaft seal, crank bolt and washer (DX item) All wiring cleaned/taped up 68mm pulley SNS 5.5 chip LEDA suspension new G60 top mounts, stops and bearings New coolant expansion tank Exterior Paint in good condition, though not perfect, due to age obviously Black badges front and rear Smoked side indicators Silver side strips with Corrado enscribed New door handles Lupo GTI wipers Uprated headlight loom with VAG multisocket connectors New headlights Front end respray Borbet B (from E30 M3) 7.5 x 16 ET 20 Yokohama A539 215/40/16R's all round New wheel bolts Borbet locking caps Interior Full black leather (unheated) Full black interior - dash and carpets New solenoids on all locks VAG center console with boost gauge Extra keys cut Just Mats floor mats DDI gauges with reverse filters New water seals on doors Momo Race wheel Passat collapsable cup holder! New driver seat bolster Been off the road for nearly 9 months now while I've slowly worked on it. Can't wait to make this my first car again... A few pics (needs a good clean and polish to get it shining again)... Quote Share this post Link to post Share on other sites
junkie 0 Posted February 21, 2007 looking tidy matey 8) Quote Share this post Link to post Share on other sites
_leon_ 0 Posted April 19, 2007 and after a good clean... gave it the clay bar, scratch-x and a wax to protect until next go. looks a good bit better... lots of other things being fitted too. though cosmetically, the grill and plates needs to be changed next. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted May 2, 2007 Should be back from Star Performance on Saturday AM - will have the below done: - quieter exhaust! - mocal oil cooler - leda suspension with new top mounts, bearings and stops - geometry sorted - fuelling and timing all set up and dyno'ed - and mot'ed... seriously i can't wait to have it back again... lots to do once it's back again - but not after a full weekend of driving. got a track instructor session at knockhill on tuesday evening - i think its an hour/25 laps. has anyone done this before? Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted May 2, 2007 What cooler did you go for? You should notice a big drop in oil temp. are you keeping the standard oil cooler or ditching it? Quote Share this post Link to post Share on other sites
_leon_ 0 Posted May 2, 2007 mocal 13row. not 100% sure on the last question - left it in with star - letting them fit and decide. what did you do? Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted May 2, 2007 Fitted the cooler and took out the standard heat exchanger/cooler. takes a wee while to get up to temp but keeps it about 10-15 degrees cooler when running.Only thing with that is you have to bypass the original cooler with water pipes from a mk1. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted May 2, 2007 i have those mk1 pipes - so expect that'll be the route taken. not too worried about the extra time to heat up - i'm positive I've read accounts of the heat exchanger failing and mixing water with the oil - clearly not a good thing. Quote Share this post Link to post Share on other sites
