vr-man 0 Posted January 18, 2005 Hi, I've done lots of forum searching on this one. My VR6 will start properly for a few weeks then develop a starting fault. No matter how many times I start it or how much I rev I give it, the engine will fire up then die completely 1 second after firing up. Then a few days later all will be fine. It seems to be worse during the colder months. The posts I've read seem to suggest a faulty factory fitted immobilizer. So I did some investigation and this showed the VW immobilzer ( Reader Coil e.t.c. ) is either faulty or no longer a part of the immobilization system. The after-market alarm/immob system is ok as I've had it checked. I'm guessing that the after-market system immobilizer may have taken the place of the VW one, which would leave me with an engine sensor fault to sort out. I wonder if any one else has had a similar problem. Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted January 18, 2005 Take it to a gararge which has VAG-COM, get it plugged in (if you can start it :wink: ) It will most likely narrow down the problem. If your car is a '95, the problem may lie with the transponder in your key or the coil next to the key barrel which picks up the key code If you've got a spare key, try using that. The stealers charge £50 to have your key code reset Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 18, 2005 When you say it "dies" does it stop instantly, as if all power/fuel was removed, or does it kind of splutter to a halt? Do the dash lights come on when it happens? (I.e. charging and oil pressure etc) Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted January 18, 2005 sounds exactly like what happened to mine. new coil 25 quid from vw problem solved Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 18, 2005 happened to my g60. bad earth. happened to missus polo. blown fuse. Quote Share this post Link to post Share on other sites
vr-man 0 Posted January 18, 2005 Thanks for your suggestions. When the engine cuts out its instant as if all power and fuel is stopped. I havn't noticed if the charging and oil pressure lights stay on when it has cut out. Its starting ok at the moment so will note next time. Funny thing is I have disconnected the Reader coil to investigate and its running!! Thats why I thought maybe the VW immobilizer could be redundant in my system. I think connecting to VAG-COM is the way forward at the moment to see if the ECU is communicating to the VW immobilizer. A bad earth also sounds a possibility. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted January 26, 2005 CHECK fuse 16 (fuel pump) Quote Share this post Link to post Share on other sites
Rams 0 Posted March 15, 2010 Hi, I have the same issue, probably starts and dies once in 30 starts or so. What I do, which could be just luck, is I blimp my cobra alarm inside the car so it locks, then unlock and she starts straight away. I had my car plugged into a snap on fault reader and the code 17978 '' engine start blocked by immobilizer.Ive also had 01176 Key signal too low and 00546 Dara wiring faulty not a plausible signal. Will try the above suggestion to clean earthing contacts and take it from their. Have you changed your coil reader to see if that sorted it? Quote Share this post Link to post Share on other sites
Gareth_16V 0 Posted March 15, 2010 Definitely check the connections to the immobiliser control box which sits behind the driver's side dash undertray. This reads the signal coming from the reader coil and sends it to the ECU. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted March 15, 2010 check fuses. then: unlock car turn on ignition have a cup of tea........ oh go on then have a biscuit too make sure you dont rush the tea (give it 10mins) turn car over has happened a few times to me. cost me a new starter on my old C as i didnt know this trick and kept turning it over ruining it. then it happened again while on a date!! :D very nice man from RAC came out who used to work at VW and did the above (apart from the brew) I could have kissed him!! But didnt - after all I was on a date :lol: Hope this helps buddy :) Quote Share this post Link to post Share on other sites
