Riley
lambda wiring issues,,,page 4 :!:
I fixed my wires with super glue as a temp fix, however, to do it prop drop a bit of solder into the connection and push the wire back in with cleaned up bare end. Hey presto, fixed. By the way, black wire is the inner free slot and the purple is the outer.
thanks rustynuts 8)
what effect will this be having?
and do i need to dig out the little rubber bit? im guessing so.
also will the loom come away from the car,would make it a lot easier!
cheers,neil.
sorted the lambda wiring,just need to make it water tight tommorow.
has made a hell of a difference to pottering about!
ill also pick up some hose for the ecu tommorow,does not being the right lenght affect performance?
cheers guys 8)
neil.
Sounds like you have been running in Limp mode. Did you notice a difference in fuel consumption once you wired in the Lambda?
The hose from the ECU must be 1 meter long and will make a difference...
thanks m8. :)
ill have to see how it does on fuel,will it have used more in limp mode?
neil.
i just filled it with optimax today,ill see how i do on the mileage front! 8)
neil.
Without a reference from the lambda probe the ECU assumes the worst and piles in the fuel so you don't blow the motor up.
If teh pipe is less than 95cm you would notice it bogging down at low revs and flying at the top end. My guess is that the pulses in the inlet manifold take a certain amount of time to reach the MAP sensor and if they arrive out of sync they confuse the hell out of the ECU.
Gavin
cheers m8 8)
reminds me,i replaced the ecu hose today,no noticable difference but at least i know its right now.
just need to buy some more to do the other little pieces to the fpr etc...
neil. :D
neil.
You will be fine until you boot it, and you will because you won't be able to help it. :lol:
aye :lol: i learnt that the day i bought the c,the drive home was expensive,but fun :D
neil.
