rado-steve 0 Posted March 26, 2005 Hi All, Was reading Buyers guide earlier. My car is a '90 Valver, but has late spec bonnet as in _--_ with bulge for VR, but has early style bracing underneath????????? weird, i am sure the bonnet has not been replaced as there are no disturbed bolt marks around the hinges etc etc any ideas??? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted March 26, 2005 take some snaps dude Quote Share this post Link to post Share on other sites
Campaign 0 Posted March 27, 2005 It's a fairly straight swap between the two, so could've just been changed without too much disturbance on the bolts. AFAIK they stopped producing indented bonnets years ago, and VW have no stock of them at all. Quote Share this post Link to post Share on other sites
JBOB 0 Posted March 27, 2005 Can i just clear this up for my own benefit (sorry) Early bonnets go down in the middle ---___--- just like a MK2 golf for example and the late ones go up in the middle ___-------___ is that right. Its just that mine is a '90 valver and the bonnet goes up in the middle :roll: I know my bonnets been off in the past cos it was painted black by the last owner to try and make it look like a carbon item :roll: :roll: :roll: Quote Share this post Link to post Share on other sites
Riley 0 Posted March 27, 2005 JBOB, yep you got it m8. :thumbleft: your c has a later bonnet fitted. neil. Quote Share this post Link to post Share on other sites
JBOB 0 Posted March 27, 2005 JBOB, yep you got it m8. :thumbleft: your c has a later bonnet fitted. neil. Cheers mate :D Quote Share this post Link to post Share on other sites
rado-steve 0 Posted March 27, 2005 yeah but the bracing from an early bonnet is totally different to a late one???? is that right? Quote Share this post Link to post Share on other sites
Bobby 0 Posted March 27, 2005 i'm pretty sure they look fairly similar, i cant see someone splitting the braceing from the bonnet skin and re attaching a new skin, would be tricky and difficult to hide the joing seam, but you never know? Quote Share this post Link to post Share on other sites
JBOB 0 Posted March 27, 2005 Would i be right in saying that to change the from early to late bonnets you have to also change the front wings............or am i just going mad. Quote Share this post Link to post Share on other sites
Tekara 0 Posted March 27, 2005 I would have though its just a straight swap no need for wings, after all its only the centre with any difference between them. Quote Share this post Link to post Share on other sites
flusted 0 Posted March 27, 2005 i changed my bonnet from early to late,no need to change anything else Quote Share this post Link to post Share on other sites
JBOB 0 Posted March 27, 2005 I wonder where the hell i got that into my head then :lol: sorry !!!!!! Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 27, 2005 AFAIK - the profile of the front wings is very slightly different. Early bonnets don't line up properly with the later wings - not sure about the other way round though. Quote Share this post Link to post Share on other sites
Riley 0 Posted March 27, 2005 I wonder where the hell i got that into my head then :lol: sorry !!!!!! heh he wasnt me was it m8? :lol: Quote Share this post Link to post Share on other sites
flusted 0 Posted March 28, 2005 The later wings are slightly wider but AFAIK theres no difference near the bonnet,its only on the arch.I actually have 1 late wing 1 side and 1 early 1 the other! Quote Share this post Link to post Share on other sites
Henny 0 Posted March 30, 2005 yup, got a late bonnet on my early G60 and the profile down the wing is identical, it's only the flaredness (is that a real word?!?) of the arch which differs on the front wings (and it's about 8mm difference! :crazyeyes: ) beeftech, the early bracing was symetrical and pretty much a triangle shape IIRC, the later bracing isn't symetrical and has a larger space without bracing over the engine than over the gearbox to clear the VR6 engine. If you've a late bonnet skin with early symetrical bracing, someone's done something a little odd... :| I know my early G60's had a new bonnet on it (as well as headlight and slam panel) at some point in it's past (even though it's HPI clear) after hitting a post of some description as the dent in the bumper is still there! :roll: :lol: You'll probably find that if you have a late bonnet on an early car, your car will have had a similar light bump to my Grey G60 and it was impossible to get hold of a new early style bonnet when the accident occured... Quote Share this post Link to post Share on other sites
diggerbucket 0 Posted March 31, 2005 So can you fit an old style bonnet to a VR? Or was that the whole point of the change....? Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 31, 2005 So can you fit an old style bonnet to a VR? Or was that the whole point of the change....?I always understood that the bonnet was redesigned to accommodate the size of the VR6 engine, although early bonnets have been fitted to VR's with limited success. Quote Share this post Link to post Share on other sites
Henny 0 Posted April 1, 2005 an early bonnet CAN be fitted to a VR6, but you REALLY need to make sure that your engine mounts are spot on else you'll end up with a dented early bonnet! :lol: The clearance difference is around about 15 to 20mm difference, but that's enough to help with clearing the VR6s inlet manifold under "spirited" driving on less than perfect engine mounts... ;) Quote Share this post Link to post Share on other sites
