Jim
The "what I did to my Corrado today" thread...
booked her in to have some braided lines fitted and rode past as i went out ( stonking weather)
interview on wednesday which if i get it will mean 9 months in germany training, 3wks there, 1wk home etc...nuremburg
any more good parts out there than here ??
Had my Toad AI606 Alarm fitted today with dual prox, shock sensor & Pager.
The guys did a really top nothch job and brought to my attention a couple of issues that need addressing with the fuse bx, due to the previous mickey mouse alarm installer.
Nothing someone in the VW know about electrics can't solve for me, looking like i might give Midland VW a ring and see if they can help
chris
i replaced the fuel feed pipe that runs from the filter to the engine bay.
the old one looked okay so im baffled as to where the fuel patch was appearing from :?
neil.
Replaced the oil cooler seal after it failed driving back from work and dumped all the engine oil over the road.Oil pressure warning light and buzzer went off but stopped in time to save any damage.
Never heard of this seal failing before but oil cooler was on tight and seal had twisted and split at the rear.
Definately fitting an oil pressure gauge and higher pressure warning light, if it had been on the motorway the engine would be dead. :roll:
Took mine to the $tealers to get the key's recoded.. :roll:
Was there at 8:45. Went back there at half past five and it still wasnt ready! It's a 5 minute job ffs!! :x
When it was finally ready, the 'sales assistant' (or whatever they call em) drove it out from round the back. Looked really good, funny how you dont realise just how sexy the Corrado is until someone else drives it & you're outside watching 8) :)
sheared my old aerial's screw, then did the same to the new one :D
lock plunger fell off, got me mum to fix it! haha
good point joebloggs, they look great when they roll past
lucky man!
im wanting some better way of keeping check on the pressure too,suppose its how quickly you can react as well though.
neil.
Fitted my BMC at the weekend and fitted a VF engine mount using my garages facilities on the way to work thismonring. Its now driving and sounding rather well.................
collected my car from the local garage, who kindly fitted a new brake slave cylinder for me...
ordered my new fk highsport coilovers!!
Finished swaping over my FK coilovers to Koni TA's with H&R springs. Changed both the front anti-roll bar bushes.
Took the passenger side wheel arch liner out, gave it a good clean and hosed it with fresh waxoil.
Can't tell you what the difference is between the FK's and the Koni's as the car is OTR while I do my engine build and swap.
greased up my TT seat runners amazing how much better they run when greased properly!!!
sat and waited for my new fk highsport coilovers tobe delivered!! Grrrrrr :D
got a call off the vw specialist who is fitting my goodridge lines, said he cant supply just the fronts (come as a kit), so i would need a full set , he said £50 for the lines and £40 to fit them .sounds good to me as he wanted £30 to fit just the front :-)
ive just picked up my raddo from the stealers got its annual service, the fan controlls fixed (would only work on 5) and the lupo wipers i ordered fitted oyea and it cost me €430 including €70 vat ......fooking hell €70 just on vat
another question lads every time i turn on the car the oil light flashes a few times i thought it was because the oil was low (it was but left it a few days untill todays service ) but after todays service it still flashes a few times on startup.. anyideas or is this normal?
finally got her back today, picked up at lunch time they had done the timing wrong so i printed off hennys directions took it to them hey presto it is fine! geometry also done she handles like a dream!! funnily enough the steering column doesnt click any more!? got hoe and my ABT skirts arrived 2 days from austria not bad!! today was a good day!!
drilled a hole in the inner rear arch for the syncro tank breather.
Actually I did this a fortnight ago but its all I have to offer at the moment
Drove the 24v V6 all the way home to my parents place (150 miles) without a single problem. Ran at 90 degrees C the whole way and absolutely flies!! Bit noisy with absolutely no interior trim at all, but that is what I have come up to crack on with. Couple of little niggles, like I am still far from happy with the brakes, and the cruise control didn't want to work :(, but otherwise. All good.
Jay
Will this be finished for E38 mate you reckon? Would love to see it, along with everyone else im sure!
i just went for a drive just couldnt resist! ive done so many jobs on her over the month she was off the road, id forgotten id fitted gavins loom and fixed the light on the heater panel! wow those lights are good now! I also offered the new skirts up propped on paint tins im really not sure whether to go the same way as Oettinger SLC and smooth the line or leave the line on them ill post some pics and see what folks reckon, if you read this Oettinger SLC cheers for the advice on the golf mk3 skirts they are just what i wanted!
Yes Nick48480 it will be there. Finished hopefully.
I am working on the interior this weekend, but everything is a long process at the moment!
I still need to sort wheels etc.. out ready for E38, but hopefully it will all come together over the next couple of months!
Jay
