Critical_Mass 10 Posted December 18, 2009 Broke down! :( Got a mile away from home when i could smell burning. Looked in mirror and rear wheels were smoking away - handbrake and froze on. so had to get towed home. They seem to have released more or less now - i think. But the handbrake isnt right. Going to have to strip the brakes when snows gone. Shove a new set of handbrake cables on it, that ought to sort the issue out. I used to have to leave mine running for a while so the underside of the car warmed up and the cables defrosted. Yeah i may have to. Is it as simple as i think to change them. Undo them at the mechanism under the trim in the car and also on the caliper. Then slide them out of the tubes they run through under the car - all in reverse to refit? Quote Share this post Link to post Share on other sites
Toad 0 Posted December 18, 2009 Yeah, only thing is the metal tubes they run through from inside the car to the underside can corrode causing the end of the cables to stick inside them. I ended up having to melt the end of the cable then drill the remains out of the tubes, nothing too serious, just a pain in the arse. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 19, 2009 Yeah, only thing is the metal tubes they run through from inside the car to the underside can corrode causing the end of the cables to stick inside them. I ended up having to melt the end of the cable then drill the remains out of the tubes, nothing too serious, just a pain in the arse. Noted :salute: I'll take a look once the snow has melted a bit. Cheers! Quote Share this post Link to post Share on other sites
coolrado 0 Posted December 19, 2009 best way to get the end of the plastic guides out of those metal tubes is slide the metal tubes out through the gromit in the floor and just get a blow torch on the end of the metal tube while you pull the plastic guides out, they should come out nice and cleanly, i had to replace both of mine last week, it's also worth giving them a rub down and a decent coat of hammerite to stop it happening again. I found the cheap eichers handbrake cables from euro car parts where better than the vw oem ones and they seem to give a much firmer hand brake feel. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 19, 2009 best way to get the end of the plastic guides out of those metal tubes is slide the metal tubes out through the gromit in the floor and just get a blow torch on the end of the metal tube while you pull the plastic guides out, they should come out nice and cleanly, i had to replace both of mine last week, it's also worth giving them a rub down and a decent coat of hammerite to stop it happening again. I found the cheap eichers handbrake cables from euro car parts where better than the vw oem ones and they seem to give a much firmer hand brake feel. Thanks Coolrado! How much are the cables? Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted December 19, 2009 £20 max from a dealer Quote Share this post Link to post Share on other sites
coolrado 0 Posted December 19, 2009 best way to get the end of the plastic guides out of those metal tubes is slide the metal tubes out through the gromit in the floor and just get a blow torch on the end of the metal tube while you pull the plastic guides out, they should come out nice and cleanly, i had to replace both of mine last week, it's also worth giving them a rub down and a decent coat of hammerite to stop it happening again. I found the cheap eichers handbrake cables from euro car parts where better than the vw oem ones and they seem to give a much firmer hand brake feel. Thanks Coolrado! How much are the cables? £8.09 each plus vat for euro car parts, I did replace them about 3 years ago and used the genuine vw ones but the rubber bellows on the end of the cables had fallen apart and allowed water into the lining so they had both rusted up, the bellows on the eicher ones seem better quality to me but i suppose time will tell. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 19, 2009 OK cool. Thanks guys I've been out in the car today and all seems well, even the handbrake is back to how it was before. Though, i think i'll still see about changing the cables. Quote Share this post Link to post Share on other sites
Wompa 0 Posted December 20, 2009 I bought a single wiper for my Corrado... For 3£ :lol: Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted December 21, 2009 My car hasn't had a steering wheel for 4 days now. The metal bit that knocks of the indicators off has snapped off the boss so I'm waiting to get some liquid metal to weld a new bit on :( Quote Share this post Link to post Share on other sites
millerman 0 Posted December 21, 2009 DE ICED IT AND DROVE IT :D Quote Share this post Link to post Share on other sites
Wullie 1 Posted December 21, 2009 Bought and fitted a new starter motor. Bump starting down a snowbound cul de sac is ar*epuckering stuff. Still trying to thaw my hands out. Quote Share this post Link to post Share on other sites
Guest Posted December 21, 2009 DE ICED IT AND DROVE IT :D Likewise, drove it :) I had 3 to choose from (4 if I count being fully comp on Kips 8v), guess which one I took out????? Quote Share this post Link to post Share on other sites
aide 0 Posted December 21, 2009 fitted new ngk plugs, cleaned properly around the airbox and around the bay generally :) discovered the bonnet earth strap had bust :| Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 26, 2009 re-fitted the cover on top off the radiator clips ×2 v811 807 577c screws x2 vn 013 938 3 screws x1 vn 013 975 202.8l 24v Climatronic system.pdfPhoto0004.jpg[/attachment:2cr19mo6]Photo0005.jpg[/attachment:2cr19mo6] :D :D Quote Share this post Link to post Share on other sites
culshaw 1 Posted December 26, 2009 fitted new rear disc bearing and pads, smoooooooth rolling no more limping corrado! Quote Share this post Link to post Share on other sites
Chris Smith 0 Posted December 27, 2009 Removed front bumper, ready to be resprayed. Quote Share this post Link to post Share on other sites
Mystic Rado 0 Posted December 27, 2009 Replaced the passenger side headlight glass before driving home - stone strike had cracked it into two pieces. Time to order some of those headlight protectors I think... :? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted January 1, 2010 Been really busy on the car today! Replaced gearbox mount (+ most of the bolts) with a new, OEM mount. Replaced rear engine mount (+bolts), with Vibratechnics mount. Replaced earth strap from coil to block. Fitted bonnet earth strap as the car's not had one since I've owned it. Fitted battery cover (Christmas present 8) ) Quote Share this post Link to post Share on other sites
aide 0 Posted January 1, 2010 oil & filter change and went for a blast :) Quote Share this post Link to post Share on other sites
dragon green 4 Posted January 1, 2010 Replaced the heater matrix, Ran out of daylight, just got to put the undertrays in,and give it a good hoover ! Quote Share this post Link to post Share on other sites
samthegram 10 Posted January 2, 2010 Brushed lots of snow off my C' and fitted my new Sparco 300 steering wheel. :grin: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted January 2, 2010 Sorted mate's Golf rear pads and then looked at changing my sticking throttle cable and found the lever at the top of the peddle wasn't in-line with the cable run, percussion adjustment carried out, sorted. 8) Then found the throttle butterfly is sticking when I was so sure it was the cable at fault from previous checks - wasted money there then. Got cold and dark so cleaning it tomorrow. Quote Share this post Link to post Share on other sites
krnau 0 Posted January 3, 2010 modded an exhaust cam to be used as inlet, not sure about the new timing mark I have done anyway :cuckoo: any help on this? Quote Share this post Link to post Share on other sites
lauraJ 0 Posted January 12, 2010 Got my late christmas present - pressed plates from Dubmeister :D oh... and got rescued by Jim, classic non start of my car and being so feeble I couldn't get my temp sensor off. Jim happend to walk by in Sainsburys car park and helps me out :notworthy: :lol: Quote Share this post Link to post Share on other sites
