gradeAfailure 0 Posted May 16, 2005 That was actually my next thought...! Though I was speaking to g-man at No-Rice about fitting a MK1 Golf GTi sandwich plate and air-oil cooler, so this may have to be investigated, along with a Neuspeed stat to keep the water temp down a bit too... Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 16, 2005 yeah...but like you said before...it would be nice to know why it was running at 1 temp for the first 100k or whatever....and now its started to run hotter before, fitting oil coolers etc..... Quote Share this post Link to post Share on other sites
Henny 0 Posted May 16, 2005 corradowales, 'cos the oil cooler has finally become blocked enough to make it innefficient? Think about how much liquid (both oil and coolant) has been pumped through that oil cooler over the 100K miles it's been fitted to that engine... Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 16, 2005 yeah...sorry should have put it differently.... it would be nice to know why it was running at 1 temp for 100k or whatever....and now its started to run hotter, before fitting DIFFERENT oil coolers....as Henny said..i'd try the standard one first.....before trying the mk1 gti thingamyjig???.... Quote Share this post Link to post Share on other sites
Henny 0 Posted May 16, 2005 ah, gotcha... 8) Personally, I'd just dump the water-oil cooler and throw it in the bin and fit a Mocal one instead... Much better cooling... 8) Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 16, 2005 So what's the deal with ditching the water/oil cooler then - as in, how to go about it? g-man said to use the MK1 GTi sandwich plate as it has the two oil lines coming off it to go to a air/oil cooler (Mocal or otherwise), but what to do about the coolant hoses that normally go to the factory oil cooler...? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 16, 2005 Nah, he meant the MK1 pipes that don't have the extra outlet to the OE heat exchanger, The sandwhich plate is aftermarket and goes in place of the heat exchanger and feeds off to the remote cooler (Get one with a thermostat in it) Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 16, 2005 Ah, right... :) :thumbleft: Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 19, 2005 Right, have decided to simply replace the factory oil cooler with a new one, and stick in a Neuspeed stat to keep the coolant temp down (which hopefully will arrive today 'cos I'm doing the work tomorrow afternoon... So: any advice on changing the cooler? Is it just the hex key bolt on top of the mounting that holds it on, or is it secured differently? Oh, and anyone know where the coolant temp sender for the gauge is 'cos I'm replacing that as well... Ta muchly! :) Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 19, 2005 cool...will be interested to see if it works......need to get my temp down too! by the way....will you taste this cake before i eat it?....im not sure if it's poisoned??? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 19, 2005 Errrrr, anyone...? Quote Share this post Link to post Share on other sites
RW1 0 Posted May 19, 2005 What's the coolant mix ratio your putting in each time? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 20, 2005 2:1 water to coolant... I have been searching a bit and it seems like I need a 30mm socket to undo the securing nut for the cooler - can anyone confirm/deny this? Quote Share this post Link to post Share on other sites
Baz2004 0 Posted May 20, 2005 30mm socket will do the job be careful if you don’t have the oil filter drained you’ll get your shoes painted a dirty shade of brown! The oil temp sender is at the back of the mounting the switch at the front is the pressure switch as far as i remember. Might be worth going with a more concentrated ratio on the coolant 1:1 perhaps esp if your having heat problems. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 20, 2005 50/50 coolant to water is not needed in the British Isles and too much Glycol actually reduces the water's ability to absorb heat. 60 water, 40 G12 is the max.....I personally run 70 water, 30 G12 and my temps are never an issue....and that ratio is good for -15 or something, which is plenty for this country. Quote Share this post Link to post Share on other sites
RW1 0 Posted May 20, 2005 Yep, agree with Kevhaywire which why I asked. Tend to find all VW's run hotter with a 50%/50% mix. 70/30..... south of Watford Gap only! Take a look at the auxiliary water pump. May be worth while taking it off and check it's actually pumping. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 21, 2005 Don't think the 8v's have an auxiliary pump... Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 21, 2005 i think i might go for another coolant change paying more attension to the mix....new thermo from the stealers....and a new water pump.....gotta get it down again somehow. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 21, 2005 Well, D-Day is tomorrow (Neuspeed stat needed a signature so had to get it from the sorting office, bah), so will let you all know what the outcome is! Quote Share this post Link to post Share on other sites
Baz2004 0 Posted May 21, 2005 Must be the grade of coolant Im using, I was putting in a good concentrated mix in my valver when i had head trouble, it seemed to keep things a tad cooler, although I was topping it up every week or so. I also found replacing the oil cooler on my valver helped get the oil temp back under 120. Don’t know if this would be the same in the 8V as it seemed to be a valver issue. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 22, 2005 Well, after much cursing today (and it will continue tomorrow), I can confirm that the nut holding my oil cooler on was NOT 30mm, but 27mm... And it's leaking at the coolant outlets on the new cooler, so I'm gonna have to replace the spring-type hose clamps with worm-drive ones before I can report back as to whether the problem is solved... Damnit, I just want to enjoy my car, not p1ss about fixing it all the damn time... Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 22, 2005 argghhh...if its not one thing its another....hope you get it sorted without too much more cursing! Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 27, 2005 WOOOOOOOOO-HOOOOOOOOOOOOOO! :cheers: She is fixed! New Parts: New standard oil cooler New oil temp switch Neuspeed 180deg stat (that's 80deg C to you) Full coolant flush Oil change Temps are now: Motorway: Coolant - 80-85, Oil - 110-112 Town: Coolant - 85-95 dependant on traffic, Oil - around 106 It could just have been something as simple as the oil temp switch on it's own, but I'm not too fussed to be honest! Thank-you to all of you who made suggestions and offered sympathy - it has been very appreciated! Right, now to fix the rest of the stuff that doesn't work...! :lol: Quote Share this post Link to post Share on other sites
Walesy 0 Posted May 27, 2005 thats awsome news gradeAfailure, ...i'll do exactly the same to mine and keep my fingers crossed that it works!. Good news though!..... :D Quote Share this post Link to post Share on other sites
