dannyc
brake lights constantly on....
Hi
i just bought my first VW C yesturday. the last owner chose not to tell me that there was a problem with the rear lights :roll: i only found out on the way home that the brake lights are constantly on, one of the headlight bulbs has gone and the headlights won't turn on unless you put it on full beem!
has anyone else had simliar probs with there C? and if so how do i fix it?
i'll get some piccys up soon :D
check your fuses for the headlights (although it could also be the switch)
Brake lights sounds like a dodgy brake light switch or a damaged wire...
thanks i'll have a look tomorrow.
it has got the uprated headlight loom, could that be fitted badly?
grrrrr...barstewards....why cant people just speak the truth when selling something like a car....i doubt its something that would make or brake a deal!. :roll:
If it works out to be the switch let me know mate...i just may have a spare one for you :wink:
oh..and welcome to corrado ownership :D
EDIT- deleted spare r in spare
dannyc, if it's got an uprated loom and your headlights will not work on dipped, then it could be the relay is bust (that was the problem on mine).
Welcome to the forum,
Tom
i've checked the fuses and their all ok but i can't see the brake light switch. i was told its behind the pedal and that the pin could of come out, is that right?
Try lifting the pedal to see if the lights go out, it could have dropped. Ive seen it before, though it was on a fiesta!!
the pedal won't lift at all
i've taken all of the trim out so i can have a good look around and i've found quit a few diconnected plugs :? i've put two back together that look right but they haven't made a difference to my situation.
can anyone tell me exactly what the brake switch looks like and the relay for the front lights. i haven't got a workshop manual yet.
whats happening is when i brake the tail lights come on and when i put my lights on the brake lights come on.
