Riley 0 Posted June 3, 2005 alright guys :D ive decided to go for said wheels,9x16 all round after having a couple p/shops done 8) . the thing is ive searched and seen many differences of opinion on et and tyre size. would anyone running this size and coilovers be able to measure how much room they have between wheel and coilover body? its just that on the mk1 i was able to stick to et35 when running 9x14's and coilovers,so what et do i want on the rado all round? im running fk konigsports,also any pics/opinion on tyre size,i dont mind a slight stretch. cheers,neil. :) Quote Share this post Link to post Share on other sites
carpoid 0 Posted June 3, 2005 Black centres look amazing !! 9 is too wide tho dude, unless you don't mind them out of the arches or getting them pulled out.... Quote Share this post Link to post Share on other sites
Riley 0 Posted June 3, 2005 aye i dont mind them sticking out m8,i quite like it in fact :D arch work will have to be done at a later date if needed,but ill still have the porsche rims. cheers,neil. Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 4, 2005 9x16 et 15 with 205/40 tyres all round should do the trick nicely not feeling the black centres but flat caps is a must in my opinion Quote Share this post Link to post Share on other sites
Riley 0 Posted June 4, 2005 cheers furki,maybe its the added sunstrip thats not looking right? its too black i think but anyway :lol: yeah,flat caps will be a definate! et15 all round? and anyone any pics of there tyres? etc? thanks,neil. :) Quote Share this post Link to post Share on other sites
Bally 0 Posted June 4, 2005 Black centres with flat caps.. I'd run 195/40/16's for the stretch!!! Quote Share this post Link to post Share on other sites
Riley 0 Posted June 4, 2005 that would be a stretch!! :shock: if i run 205/40's will i have clearance probs? neil. Quote Share this post Link to post Share on other sites
chrishill 0 Posted June 4, 2005 black centers yes...sunstrip no... I've got 205/40's on my 8" wide 17's and they do sometimes catch with a 60mm drop, although not much. what offset are the borbets? - edit - whats the little badge above your indicator? is that a german flag? Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 4, 2005 heres mine with 205/40/16 on 9x16 wheels Quote Share this post Link to post Share on other sites
Riley 0 Posted June 4, 2005 what offset are the borbets? - edit - whats the little badge above your indicator? is that a german flag? cheers m8,been told if i go 9x16 then they only come in et15,yep german flag just above the side repeaters :) (see pics) neil. heres mine with 205/40/16 on 9x16 wheels thanks m8,looks good! 8) do you have catching problems? and are you running coilovers? whats the ride height? etc etc :lol: any more pics,opinions appreciated! thanks,neil. :D Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 4, 2005 got avo coilovers lowered 60 mm no probs with arch mods Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 4, 2005 Bally, 205/40 is def enough u nutter :lol: Quote Share this post Link to post Share on other sites
Riley 0 Posted June 4, 2005 got avo coilovers lowered 60 mm no probs with arch mods sorry m8,you mean you dont have/need arch mods? :oops: thanks again! neil. Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 4, 2005 yeah arches have been modded Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 4, 2005 thorpey, curious, what suspension are u running Quote Share this post Link to post Share on other sites
Riley 0 Posted June 4, 2005 he's running avo coilovers furki m8 :wink: did you have metal cut away thorpey or roll/fold the lip? thanks,neil. :) Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 5, 2005 fronts folded and rears cut Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 5, 2005 fronts folded and rears cut hmmmmmmm although i have 7.5 front and 9 rears i had the fronts cut and rears rolled??? bizarre, works though :? Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 5, 2005 must admit rolled looks better Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 5, 2005 :lol: i like cut better, oooops depends how low you want to run it, ilike my lowered, hard Quote Share this post Link to post Share on other sites
thorpey 0 Posted June 5, 2005 yeah low looks nice and aggressive Quote Share this post Link to post Share on other sites
Riley 0 Posted June 5, 2005 im not confused,honest :lol: neil. Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 5, 2005 Riley, to be totally honest: mine are cut-front rolled- rears another 91 g60 rolled flat- rears std- frot 9x16 all round rubbed like crazy on rears another 90 g60 rolled- rears std- fronts ran fine no rubbing another g60 sitting slightly higher than mine at the front required no arch work on the front on same rims all examples are given from cars ive seen running jus not named names, jus in case..... so it really depends on ya car mate tbh,,,so stick the wheels on and see what happens,,, jus budget for the worse and if ur arches dont require work its a bonus thats how i did it Good Luck Quote Share this post Link to post Share on other sites
Riley 0 Posted June 5, 2005 thanks furki 8) yeah,ill just see what happens,i could at least run it a little higher if it catches anywhere for the time being. and if arch works needed id probably have a go myself :) ok guys,who did your arch work? thanks so far,neil. Quote Share this post Link to post Share on other sites
