Madjackal
Headlight lenses
Anything tricky about fitting?
By the way cheers steve!
very carefully prise off the clips so you don't crack the edges of the lenses, I used a flat bladed screwdriver in the centre 'hole' of each clip to bend them open a bit.
the small clips that hold the trim surround on always seem to break though :(
David.
where can i get a set of new lense's from what sorta money are they??
ECP do them for about the same money.
i can get em for £20 ea
New??
The prices have gone up and they're now £25+vat for the late ones...
The one I got the Mad Jackal was just less than £20 + vat trade!
i got one for about £24ish from GSF, prise the clips off FROM THE PLASTIC SIDE, not the glass side, then once off, DO NOT touch the silver reflector at the back, this will come off as mine did!
and when re-fitting, put the metal clips on the glass part then ease them ONTO the placstic, if you do it the other way round the glass can smash!
can you get the little clips that hold the surround on?as i was takin mine off i lost the little beggers!now my surround feels a tad loose
