Aus 0 Posted November 24, 2005 Hi, have a '94 VR6, 70K miles, serviced last month but about 6 months ago this all started ... - on cold mornings, it starts immediately and then hunts between 400 and 1500 revs until warm - when warm, always starts but turns over 10-12 times before starting (used to start immediately) - when coasting to a stop, the engine often dies - when it's warm it idles fine at about 650-700 revs - pulling and running well otherwise Have replaced the coil pack and leads, blue temp sensor, cleaned out the ISV (with brake cleaner and then lubed with PTFE oil), checked that the battery's OK. Am now stuck - any ideas? Thanks Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 24, 2005 Any error codes? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 24, 2005 This cranking over 10-12 times..... I'll wager this is happening after an about an hour or 2 after stopping, but cranking it from cold or immediately after stopping it, it's fine? That's a classic fuel pump sign....or relay 16 (IIRC), the fuel pump relay. When you've ascertained a pattern for this, remove the pump relay and bypass it with a wire and two spades (RW1 will be along in a minute to advise which pins to bridge - or Vince at stealth can tell you - i can't remember) and if it fires up quickly....it's the relay....if it still takes ages, it's the pump. Quote Share this post Link to post Share on other sites
Taggart 0 Posted November 24, 2005 Sounds quite similar to what mine did, remove the ISV damper and check the bit of foam filter in there hasn't come loose and blocked the pipe. It's a worth trying first as it's free! Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 24, 2005 I had simular problems, swapped the ECU relay and its fine now, changed the fuel pump relay first but it still stalled. Nothing to say both the ecu and fuel pump relay hadn't got problems i suppose. Quote Share this post Link to post Share on other sites
Aus 0 Posted November 24, 2005 Thanks all ... sorry, prob an idiot question but where would I find the ECU and fuel pump relays? And I assume the ISV damper is the rubber 'box' by the ISV? Thanks Quote Share this post Link to post Share on other sites
RW1 0 Posted November 24, 2005 Quote remove the pump relay and bypass it with a wire and two spades Bridge relay 12!! Marked "167", bottom row, right hand side corner. The pins are the 30 to 87 positions on the fuse / relay panel. It does mean the fuel pump is running all the time as this is bridging in the battery 12 volts not ignition 12 volts. It would be better not to do this as fuel will be pumped all the time. More difficult to do. Alternatively run a 12 volt ignition supply capable of at least 20amps load to the fuel pump relay connection pin marked 87 where the pushes into the relay fuse panel. That way at least you can turn the fuel off with the ignition key still and it will allow you to drive the car without flooding it. The only source for this with current carrying capacity is a white plug on the back of the relay fuse panel, bottom row. The middle white one. Pin 4 should have a fairly thick Black wire which will take the electrical load. Check it with a meter for ignition +12 volts before tapping in. Relays on fuse panel by drivers knee behind the removable small pocket shelf. Yes the thing like a small hip flask. . Quote Share this post Link to post Share on other sites
Aus 0 Posted November 24, 2005 Thanks - will go and investigate Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 24, 2005 I think Dinkus has a spare FP relay althoug they are not much from VW... Quote Share this post Link to post Share on other sites
Aus 0 Posted December 2, 2005 After some good advice (thanks guys) I replaced the ECU relay (cost £11) earlier this week and the signs are promising of the problems gone away ... so thanks for the help and versus what the garage wanted to do, massively massively cheaper and a lot more rewarding! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 2, 2005 Nice one, glad you've got it sorted! Quote Share this post Link to post Share on other sites
Aus 0 Posted December 2, 2005 not sure I want to be too confident yet but it's all looking good so far ... fingers crossed! Quote Share this post Link to post Share on other sites
