chrisw 0 Posted November 30, 2005 Just picked up a 288mm caliper setup on ebay for £62 including delivery.Came with pads came but no disks. I think I will get some Pagid FR and some braided hoses as everyone seems to recommend. I'm not sure what disks to get though: VAG, GSF or aftermarket ones? Can someone just confirm what braided hoses I need as well. The brakes are off a P reg Golf VR6 and I have a late model vr6. Chris Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted November 30, 2005 The brembo ones from GSF are only about a tenner more than the standard ones. Not sure if they are any better but for a tenner a disc I would go for the brand. Quote Share this post Link to post Share on other sites
Furkz 0 Posted November 30, 2005 never had problems with the zinnermann and pagid fast road pads setup from GSF Quote Share this post Link to post Share on other sites
TREVR6 0 Posted November 30, 2005 Quote never had problems with the zinnermann and pagid fast road pads setup from GSF Yea me too, had a good thrashing on track too, no signs of warpage, just a lot of dust! :D Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted December 1, 2005 I have ATE Powerdiscs (grooved), with standard pads. They work well enough, no fade, reasonable bite. BUT, they are very noticeably noisy when being used hard, a sort of rumbling groan. Which reminds me, I must call the wife........ Best wishes RB Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 1, 2005 Roger Blassberg said: BUT, they are very noticeably noisy when being used hard, a sort of rumbling groan. Which reminds me, I must call the wife........ I just spat tea over my monitor! :lol: Personal preference is VAG disks and Pagid Fast Road pads. They work well together, aren't too expensive and look standard. The Pagid pads do make quite a bit of dust, but it washes off pretty easily. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 1, 2005 Yep, VAG disks all the way, they just look suppier in quality to everything else and are even balanced, last well and aren't expensive Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 1, 2005 The current Zimmerframes are a lot better than a few years ago. Nelson Wetberry has some Zimmerframe 312s (cross dressed) on his car and they do actually look rather good. They've dropped the silly radial groove idea at last and just got on with some decent holes..... they've not warped yet either, which is a miracle where Wetberry is concerned. Might look into a set when my VAG ones are worn/warped/snapped in half.... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 1, 2005 Cross-dressed - lol The drilled zimmermans that I took off the TDI the other week were completly fuct, in 2 years and less than 30k miles they were worn well below the wear limit and the also cost 50% more than the VAG ones I relaced them with... I won't be using them again! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 1, 2005 They're the old schitt ones mate..... have a look at the newer ones, they seem a lot better. Quote Share this post Link to post Share on other sites
Pat_McCrotch 0 Posted December 17, 2005 Wetberry indeed! ;) I never really got a chance to bed them in before I sold the car to be honest, but the bite though the pedal was deinfately much better. Quote Share this post Link to post Share on other sites
Furkz 0 Posted December 17, 2005 TREVR6 said: Quote never had problems with the zinnermann and pagid fast road pads setup from GSF Yea me too, had a good thrashing on track too, no signs of warpage, just a lot of dust! :D yes too much dust mate but they stop skip free Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 19, 2005 I was thinking about brake disks over the weekend after ogling some rather monsterous brakes on a Porker... The holes are there to... Disperse heat (airflow through the disk) Keep the pad surface clean Expel gases that build up under heavy, prolonged braking Look pretty Now, all of these are only really issues if you use your brakes very hard, very often, which I'd imagine most of us don't. But having the holes in the disk also reduces the friction area and the amount of heat that the disk can absorb as well. This is even more so on the Zimmerframe disks that seem to have very large holes relative to the size of the brake disk. I haven't counted, but you must get at least 4 or 5 holes under the pad at any one time and each one is 3mm diameter? Hmm. Just a thought. Oh and the holes seem to fill up with brake dust pretty quickly too... :( Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 19, 2005 I believe mine has TarOx discs with green stuff pads (fitted by previous owner) and they seem really good. Quote Share this post Link to post Share on other sites
