Baz2004 0 Posted December 5, 2005 Does anyone here run with slicks for track days? Just wondering what’s the general opinions are with slicks what’s the best compound to go with. The name of a decent place that sells them? Which ones best suit the corrado? Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 5, 2005 If you're going to run slicks, make sure you've got a baffled sump at the very least otherwise you'll get oil starvation and a very unhappy engine. Quote Share this post Link to post Share on other sites
cata 0 Posted December 6, 2005 would you mind explaining that in detail, can't see why slicks would make a difference thanks Quote Share this post Link to post Share on other sites
billinjah 0 Posted December 6, 2005 would you mind explaining that in detail, can't see why slicks would make a difference thanks basically vw's with std tyres generate enough g's when cornering that the oil ends up too far away from the oil pump pick up so you get starvation. when you add slicks the problem (stickier rubber = more g's (from the faster corner speeds) thats why you run them) is amplified thus requiring a baffled sump which prevents the oil moving around so quickly. Quote Share this post Link to post Share on other sites
cata 0 Posted December 6, 2005 That makes sense, but what do you mean by “baffled sump”, and is this common for other cars or just a flaw the vr6 had (or still has). One last question, I’m assuming the pickup is at the bottom of the oil pan, and if it is would it be a good idea to take it off and fix the flaw? I appreciate any info you can give me. Quote Share this post Link to post Share on other sites
billinjah 0 Posted December 6, 2005 no its a flaw most production cars have do a google image search for baffled sump it may have another name in the states and ca. buts its basically an oil sump with channels to prevent the oil from sloshing around. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted December 6, 2005 :offtopic1: Quote Share this post Link to post Share on other sites
Walesy 0 Posted December 6, 2005 ^^^ not really mate, it's all to do with having slicks on... Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted December 6, 2005 id say thats not the most important point. id look at transmission, shafts cv's etc. thats where the load goes. slosh is slosh but this happens anyway. if yoy are cornering at speed and grip still, like most of us do, theres slosh. slicks on our cars may be best left for the qartermile where we need them most. to fix slosh etc get baffles and a windage tray from a tdi. Quote Share this post Link to post Share on other sites
billinjah 0 Posted December 6, 2005 slicks on our cars may be best left for the qartermile where we need them most. not at all they help you go round corners faster which is the name of the game! Quote Share this post Link to post Share on other sites
rmn 0 Posted December 6, 2005 I run Yokohama Advan Slicks on track, well i did till i killed one of them. Only run slicks on the front too the put a huge load on cv's, gearbox and bushes, but i think they are worth it as a set of slicks will do ususally a season of track days where as road tyres get killed quite easily. As Dinkus says they can cause oil surge which is not good for your bottom end barings or any of the engine. I have done a fair few track days in different cars and feel that a porperly setup car, not properly set up for road, will be quick, slicks will make the braking, accelerating and cornering. A shrick baffled sump is a good investment and a mk2 diesel windage tray too. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted December 6, 2005 I know slicks are hard on the car, and Im aware of the the issue of the sloshing. I was/am asking about the different types of slicks people use and any good places to get them. Perhaps people can give an insight into these Maxsports or remoulds road legal slicks some people use or the Michelin Exaltos. Thanks Rich I’ve heard you mention those yokos before they seemed decent for the occasional track use. Quote Share this post Link to post Share on other sites
