STORM 2
how can I tell if radiator is blocked?
Hi,
apart from the obvious cooling problems - is there a way of checking whether the radiator has a blockage? Maybe by way of volume?
cheers
Disconnect the top hose and push aside, then disconnect the bottom hose (at the thermostat housing end as access to the bottom rad hose is very tight) and blast water through it. if it runs out OK with no sediment....rad is fine. Do it both directions to make sure.
