bristolbaron 11 Posted February 6, 2006 Anyone have any ideas? when i break, my passangers side indicators come on [solid, not flashing]. Only noticed as the interior indicator was coming on! Has this happened to anyone before? i've tried the search, but couldnt see anything. Cheers, Baz. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 6, 2006 Check the earth connections on your lights,that usually causes that type of faults. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted February 7, 2006 A short circuit in the rear cluster is a good candidate. Disconnect the rear passenger-side main cluster and see if the problem goes away. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 7, 2006 Mine did this. I'd bent a couple of pins when I was swapping the rear light clusters, which resulted in the brake light earthing through the indicator circuit. Unhook the multi plug on each side and check all the pins are straight. Quote Share this post Link to post Share on other sites
selbekk 0 Posted February 7, 2006 i remember one time in our old '86 golf gti 8 valver, every time we turned left, the horn beeped. Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 7, 2006 thanks for replies, i shall try the above! selbekk, ive got one of those too, fingers crossed i dont get that problem! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 9, 2006 A short circuit in the rear cluster is a good candidate. Disconnect the rear passenger-side main cluster and see if the problem goes away. iirc this is the usual culprit or you could turn everytime you brake :wink: also check the earths around the rear cluster Quote Share this post Link to post Share on other sites
Waler the impaler 0 Posted February 12, 2006 i remember one time in our old '86 golf gti 8 valver, every time we turned left, the horn beeped. My mates 87 Jetta 16v did that, except round right corners and he had music air horns. Brilliant! :lol: Quote Share this post Link to post Share on other sites
billinjah 0 Posted February 13, 2006 baz why fix it mate it means you can slow down and curb crawl and still have a spare hand,, handy eh?? :norty: Quote Share this post Link to post Share on other sites
