OSV
Ever regretted a modification? (helpful guide perhaps)
  double-6s said:
Jade, liking your reg number :)
was thinking of getting a 666 one myself.
Thanks , a little take on Jadey (not many call me Jade anymore!)
And as for the plate
you may find it hard , the DVLA told me they were not producing anymore as people were trying to return them once they realised what the 666 stood for :evil: Dont know how true this is
When I got mine I had to agree to terms that I knew what it ment and I couldnt return it . :roll:
Would have thought that if people were that bothered about the number 666 they would never have designated a road near Blackburn the A666
My only regrets were Inpro rear lights and RH ZW1s....
Inpros cause they look mank close up and RH ZW1s cause they come with cheap arse japanese pre-laquered dish plates that don't last 5 minutes in the winter, not to mention one of the 4 arriving bent and RH's general cack customer service.
I'm going to say something controversial......uprated headlight loom.
After everyone raved about how much difference they make, I was expecting so much more. I can honestly say the lights are no more than 10% brighter and if I'd known that before I wouldn't have spent the money, no way worth the 50 odd quid I paid*, especially as the original clip fittings are so much more secure fitting than spade connectors.
*not disputing that the loom is well made or not worth £50, I just feel the improvement is not worth £50, I personally think a set of higher wattage bulbs makes much more difference.
Fla, yeah the smoked ones look OK, much better than the white/red inpros... still not my bag though.
Kebabman, my car already had a loom on it when I bought it but I can tell you this, the lights are WAY brighter than other Rados I've driven without a loom. What bulbs are you using (I use Osram silver stars) and are the headlight reflectors in good order, i.e. not going yellow? You should defo see a big improvement, something isn't right.
my biggest regret was spending a fortune on a mk2 vr6 and not just buying a corrado in the first place!!!
Biggest dissapointment was a B&M shifter. worst heap of arse I have ever bought in my life.
  16v said:
Never done anything bad to my rado.
Although there are blue neon washer jets ( Which I have disconnected ) that I want rid of.
how dare you put blue neons on a corrado, even for thinking it.
