bristolbaron 11 Posted March 2, 2006 I'm sure i saw a thread about resealing in-pro's, but can't find it any more! My rear lights have gone sludgy, and i'd like to clean and re-seal them before sunday. Can any one tell me an exact type/brand of sealant that they've used [sucessfully!] to do this?! I'm thinking i just need to: Slice through existing sealant and scrape/clean it all off, Remove gunge reseal using ______ ? Just stuck on the last bit! Also, what colour sealant should i be using?! Thanks, Baz. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 2, 2006 mine are the same,so ill be doing the same as you shortly Quote Share this post Link to post Share on other sites
Phil K 0 Posted March 2, 2006 Jet spray them round the edges - got all the carp out of mine and didn't ruin the seals either 8) Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 2, 2006 did yours go green and things started growing out of them phil? Quote Share this post Link to post Share on other sites
Phil K 0 Posted March 2, 2006 Pretty much :lol: They weren't really bad but deffo had green stuff growing in them... I tried cleaning with a cloth by gently lifting and raising the edge into the gap which kind of worked but couldn't get in to the corners... then I gave up and thought I may as well just give it a blast with the jet spray! It worked a treat but they will need doing again soon :? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted March 2, 2006 my corners are like this so just water in them i would like to re seal them like bristol baron says though Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 2, 2006 an update!.. I took my lights out, and tried to split them, but they seem to have a fold in the plastic, so you cant just cut the sealant. I've had to clean up as much as i could with an old toothbrush. they've come up okay, but theres still a line through the middle. I've put sealant around all the edges now though, so hopefully they wont get any worse. I'd still be interested to know if anyone has actually got the lens apart!? Quote Share this post Link to post Share on other sites
Furkz 0 Posted March 2, 2006 see this is why i run the hella lights in winter... :lol: i learned the hard way too Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 2, 2006 see this is why i run the hella lights in winter... :lol: i learned the hard way too that a hella 've a plan for next winter *groan* :lol: Quote Share this post Link to post Share on other sites
Tempest 0 Posted March 2, 2006 Did the same on mine about 2 summers ago: Cleaned out as much of the green stuff as possible, then resealed with clear sealant. Worked so far. Tempest Quote Share this post Link to post Share on other sites
billinjah 0 Posted March 3, 2006 cool another one for the list,, i might split mine and tint them from the inside, Quote Share this post Link to post Share on other sites
