ardandy 0 Posted March 15, 2006 Things I'm planning to do on my C. Just wondering which is the best order to do it in? I'd like the bodywork done I reckon, in time for the summer but what do you think? 1, Bodyshop visit - All I want doing (£550) 2, Koni & H&R Sus Kit Fitted (£550 est) 3, Camber adjustment (£150 VW) 4, Injectors cleaned and flow tested (£250 inc removal and put back) 5, Reverse Parking Sensors (£200 fitted, little sensors in rear bumper, not num plate) 6, Fix pass heated electric seat (£??) 7, Regas/repair Aircon (£65 if its just a regas, although poss getting done sat as I'm nr the guy in Leeds) Wow, longer than I thought! First time I've written it down! Feel free to add anything I've missed thats a good thing to do. Wanting to keep it pretty standard looking, or OEM+ as the term appears to be! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted March 15, 2006 4, Injectors cleaned and flow tested (£250 inc removal and put back) How much !!! you must be kidding,you can get new for that surely? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted March 15, 2006 7 4 2&3 1 6 5! Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 15, 2006 number five is very easy to do and can be done for less than £30 and a drill Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 15, 2006 4, Injectors cleaned and flow tested (£250 inc removal and put back) How much !!! you must be kidding,you can get new for that surely? £21 per injector (6) plus £120ish to take them out at my garage and then 2 days later put them back in again. Apparently you have to remove the inlet manifold and various bits to get them out. Brand new from VW each injector is £93! Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 15, 2006 Agree with injectors, the only thing that I have to add is that there is a bit of rust on the rear seams so I do want the bodywork doing as soon as I can. Ahhh, decisions decisions! Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 16, 2006 Personally I'd be sorting the chassis first with the suspension and geometry set-up. Following that I'd do the engine stuff before fitting the reversing sensors. Then I'd take it to the bodyshop. Do the seat and air-con 'whenever'. Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 16, 2006 Trouble is, I want it all shiney for the summer! :) Aircon getting done sat as I'm next to the guy that does it and for the sake of £65 I might as well. Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 16, 2006 £150 for the camber adjustment :shock: had mine done when i had my FK's put on i was charged £35 from midland vw. virtually any place that sells alloys can do it?? cant they.. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 16, 2006 Well, in that case, it sounds like you already know what order you're doing stuff in. Shiney it is! :) Quote Share this post Link to post Share on other sites
ardandy 0 Posted March 16, 2006 I suppose it was more of an after the bodywork order of things. £35? Sounds more like tracking to me than a camber adjustment. £75 for the readout and another £75 if it needs adjusting. Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 16, 2006 ardandy, my dealer did lot lot for 70 Quote Share this post Link to post Share on other sites
KADVR6 0 Posted March 16, 2006 no it was the camber/tracking, i do get a bit of discount there, but not £115 worth. :wink: Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 16, 2006 eip in america supply new uprated bosch injectors for about 200 quid for 6. edit: not sure what make they are actually, but they're from 49 dollars each. Quote Share this post Link to post Share on other sites
