PBSTORM
Cracked fog lights + headlight
My rado is soon due it's MOT and it currently has 2 cracked front fog lamps and 1 cracked headlight.
Are these MOT failures?
think the headlight might be a failure depending on how bad the crack is, theres a set of fogs on fleabay at the mo although dont think there to expensive from GSF.
I'd crack the other headlight aswell and then they might think it was supposed to be that way.
So long as the headlight crack doesn't affect the beam pattern, it should pass. Mine got through with a big 50p sized stone chip a few years ago.
Fogs don't matter.
I think the cracks don't matter unless there are sharp edges on the outside, or the beam pattern is wrong.
