KipVR
Check out Lupo Rear Wiper
I made this a while ago and I've been asked about it several times, it's a Lupo wiper welded to an original Corrado one.............it's a good compramise between loosing the wiper totally and being able to see out the back to see who you've overtaken!!
Both Kev and I have done this in the dim and distant past...
It's a reasonably simple mod that makes a really nice difference...
Oh, and if you order the lupo arm of an LHD car then you can get the blade to sit under the arm making it look that little bit neater... 8)
Looks good on yours though KipVR... 8)
yup... and Kev modified his Lupo arms to fit standard blades, so it follows that you can modify the standard arms to fit aero blades, although this all came about 'cos the spring in the standard arms isn't strong enough which makes your wipers pants...
/full circle...
I had it on my last g60
jezzag60 has done effectivly the same thing on the front wipers using passat blades with original Corrado arms.
I did have one on mine until Supercharged ran off with and I haven't seen it since *glares in his general direction* :lol:
