ardandy
VAG Clocks On A VR6
Come across a prob when putting the TT clocks into a VR6. The revs will be displayed wrong because the "ping rating????" will be for 4cyl, yet the VR6 has 6.
If this makes sense to anyone, is there a way around it without using different clocks? (Like the MK4 Golf in the TT binnacle)
I'm doing nothing yet. But as a new dash is out of the ques for quite a while due to finances, I thought it might be possible to just replace the clocks out of a TT/Golf etc.
This ques came about because when I spoke to Andy Walker about it he mentioned that the rev counter will be off because of them coming from a 4cyl eng and being put in a 6cyl.
Wondered if there was a way around that, other than putting V6 clocks on which are much rarer. (on the TT).
Would it be poss to fit (after dremeling) TT or Golf Mk4 clocks in the C's binnacle?
It should fit mate, as Andy will tell you "anything is possible, it just depends if youre happy with it" ;)
He was going to fit them to mine, but left it OE instead. He'll probably source you some clocks anyway.
Supercharged has them in his TDI, but he didn't do the install and he does have the Mk4 engine attached to them as well :lol:
Dash maybe some way off. Nearly £2k is a lot to fork out, especially as a partial respray and wedding has to come first!
I suppose though that the clocks can be just carried over to the new dash, and if anything, should make it a bit easier??
