Icegeezer
What Bilbs?
Ok really stupid question
I have been offered a hid kit for a good price but they need to know what bulbs the corrado runs...
I presume its 2 units,
drivings lights
main beam
but what bulbs are they
and yes I know im being lazy... :oops:
Thanks tho
Headlights are H4's
HTH
it this 2 seperate h4's??
for instance
driving light is a h4
main beam is a h4
its not a double element bulb is it.....
just thinking I might need 2 kits....
Sorry to highjack....
Just wondering what wattage bulbs corrado's should have?
I've put an uprated wiring loom in mine now, and it mentioned I could run 'higher watt/uprated bulbs'....but what do I need to go for?? :)
You don't *need* to go for higher wattage bulbs... you *can*, and there's *slightly* less risk of you frying anything or melting the reflector dish in the headlight than there was before..
Standard bulbs are 55/60 watts.
Ok cheers,
Is there much of an improvemnet or is it not really worth it?
Never done it, but I think the difference is pretty obvious. I mean, some people are fitting 110w bulbs, which obviously makes a HUGE difference. I wouldn't recommend that though, cos that works out at about 35 amps on full beam...
I suppose going to 75/80W won't make that much difference, electrically. It's still not legal though, afaik.
