double-6s
VR MAF????
Ok....
My vr went for an mot and failed quite spectacularly on emissions - CO of 10% instead of 0.3%!!
If you disconnect the MAF the CO goes down to 0.1
What does that mean?
Is the MAF feked?
Its overfueling - returning about 18mpg, but sometimes its fine and will return 26 which is ok for me.
Cheers
What about a hole in the downpipe? I got one :)
Could the intake of air from the hole make the engine think its running really lean and bung in loads of fuel? Is the lambda in the DP?
PS. Scanned twice on VAGCOM and no errors :mad:
ah ha!!!! (in alan partridge voice)
we could be getting somewhere Christopher :)
so the cat pipe being after the DP, that could be the problem then? tried 2 mafs, 2 ecu's, etc
Sounds likely, although it needs to be a chuffing great hole to get 10% CO at idle!!
Pulling the MAF causes the engine to run uber lean, so can you not blitz it through the MOT like that temporarily?
Its fine on idle with no maf Kev, but then CO nightmare again when they do the high idle or whatever it's called.
What the bleedin ell else could it be???
Could the hole in the DP fek the lambda??
It drives sooo much better with no maf!
Can anyone say why the car drives better without the maf, and why the emissions are ok at idle without the maf? Is that normal?
And what effect will running without the maf have? Damage?
Help!!
Default failsafe program - it'll run, and it'll no doubt run better than when your dodgy MAF was governing the engine using the failsafe program. It just won't make big power. If anything, I would expect it to overfuel very slightly, but it should still pass the emissions test.
If you need a new MAF pm me and I'll run you through the saga I've just had and could save you a few bob....
thanks mate. just returned from holiday driving my ex's 1.6 focus for the lst week! need to get the vr sorted :(
