akacheesy
cambelt change vr6
its a cam chain on the VR's - they normally last forever. Apparently It wrks on a self tensioning mechanism to prolong their life, i.e. its slack at first start and gradually tigtens up which is why they are a little noisy in the mornings.
I've got 136,000 on my VR, and my brother has 180,000 :shock: originals cam chains in tact
Actually I believe the cam chain tensioners are oil-pressure driven (or at least, the lower chain tensioners are). This way when the engine is ticking over and you have low oil pressure, the chain is slack, and when the engine is under load the chain is held tightly in place due to the higher oil pressure.
Abuse of the engine with cold, thick oil will prematurely wear these things, the oil pressures can get VERY high when cold.
But the general consensus on the cam chains is don't change them unless you're certain there's a problem, OR you're having that end of the engine (actually the gearbox) off for some other reason, in which case the extra parts + labour to do the chains isn't much.
Apparently... :)
The top tensioner is oil pressure fed(the big bolt screwed in the back of your chain cover,easily changed 1min max) the lower one is a manual tensioner
Top Chain Guides will wear out without you even knowing about it,as for chain slipping and knocking out a tooth ,must be well F**ked
Jeez, it must have taken you a while to get down to the point from which you could take that picture...
My bad, I was under the impression the oil/spring tensioning was the other way around.
Still, on the whole they're very reliable. (Says Matt crossing his fingers..) :)
It was a pain,would not like to it again,head was off at same time 2 and was doing rings and shells so engine was held in with one mount :shock:
The engine is so much more responsive and has a crackling sound to the intake noise
Just Love it !!!!!!!!!! :twisted:
