willg95vr6
Where is the fuel relay located on the VR6
Can any one tell me whare abouts it is located, i have a 95 vr6. is it one of the ones behind the glove box if so which one is it.
many thanks
Will
which one is the fuse relay on the 94 vr6. Fuse box is on drivers side, and the fuse numbers seem different also?
i have just noticed the fuse relay is still the bottom right as supercharged said but its is a different number. you can tell if you take it out you will find it had the same pin lay out. it is the only one that fit
thanks for that. Mines made in Portugal as oppose to Germany - what difference would this make..im guessing that it would mean that mine is not a genuine VW part?
does it really matter??
I have just found that one of the metal connectors on the fuel relay 167 is loose( compared with the others) - could this be the culprit for the hesitation across the rev range most of the time?
How much is a new one of these?
worth changing the ECu at the same time. Whats the correct number for ECU also.
So many questions...sorry!
