Bally 0 Posted October 7, 2003 as above, what is the difference between the early and later bonnets? does the early one have a recess and late have a bulge? Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted October 7, 2003 Yup, pre-facelift Corrados have a slight recess in the middle of the bonnet. Post-facelfit have a bulge, this was added to make room for the larger VR6 engine. I believe the facelift models have slightly different wings as well. And a three slat grille of course. Think the facelift occured in late '91, don't quote me on that. Quote Share this post Link to post Share on other sites
GRINGOG60 0 Posted October 7, 2003 Hi, Im not sure if im right (i never really am!) but i think it is just the VR's that got the bonnets with the bulges as my car is a face lift G60 but has no bonnet bulge. It makes sense as the VR6 motor sits a bit higher up in the engine bay. Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted October 7, 2003 all face lift corrados should have a bulge, mine was a 2.0 16v and has a bulge, and the wings are slightly wider than the early corrados Quote Share this post Link to post Share on other sites
Joe M 0 Posted October 7, 2003 GRINGOG60 said: Hi, Im not sure if im right (i never really am!) but i think it is just the VR's that got the bonnets with the bulges as my car is a face lift G60 but has no bonnet bulge. It makes sense as the VR6 motor sits a bit higher up in the engine bay. From the pic in your avatar it looks like you just have the facelift grill. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted October 7, 2003 early bonnet looks a bit like this ---___--- late bonnet looks a bit like this __-----__ and i think you will find the bulge was added for saftey reasons so the the space between the engine and bonnet remained enough that when hitting ppl the bonnet was "soft" rather that hitting straight into the engine if you know what i mean. if you look at the parts CD you will see that later models had different front and back bumper, wings, doors, all front lights, grill etc. I dont know what the difference is in the door but i noticed that there is two lots of part numbers for different chassie numbers. Quote Share this post Link to post Share on other sites
Bally 0 Posted October 7, 2003 Cheers guys, the reason I asked was that on my H plate 1991 car, its fitted with a bulge bonnet.. Quote Share this post Link to post Share on other sites
G60 0 Posted October 7, 2003 different doors jet? thats a new one by me.. what's different? just like the "what's faster, G60 or VR6" debate.. the two hoods are another age-old bickering point between G60 and VR6 owners... i believe ALL G60's had the recess and ALL VR6's had the bulge. reason being, VR6s need the extra room for the taller engine and the G60's all retained the proper corrado lines the way they were meant to be with the recessed hood as they don't need extra engine clearance (okay now VR6 guys make a rude comment about me.. alright ready to continue). the 16v and 8v varieties got whatever they had sitting around the factory i imagine!! :lol: Quote Share this post Link to post Share on other sites
Henny 0 Posted October 7, 2003 G60 said: i believe ALL G60's had the recess and ALL VR6's had the bulge. reason being, VR6s need the extra room for the taller engine and the G60's all retained the proper corrado lines the way they were meant to be with the recessed hood as they don't need extra engine clearance Wrong... It all depended on when they were built. You're right that the reason for the change was the VR6 engine needing extra height under the lid. All 1.8 16V 'rados should have the recessed bonnet, all 2.0L(both 8V and 16V) and VR6 'rados should have the bulged bonnet, G60s got a mix depending on build date. My G60 is one of the last run of G60s and I've got the later headlamps, grill, bumpers, indicators, foglamps and the bulged bonnet. (although I actually prefer the earlier recessed bonnet... :roll: :( ) VW stopped making the recessed bonnet when they released the VR6 'rado as it made economic sense to only make one part for all models rather than having to have the tooling for both recessed and bulged bonnet up and running at the same time... 8) Oh, and there was a change on the door handles too. The later ones have a lip around the key barrel... No idea why, they just do... :? :lol: Quote Share this post Link to post Share on other sites
dubboy 0 Posted October 7, 2003 I second that Henny, mine just missed out on the changes. But as I belive the front end of mine was set up ready for the changes as the later spec three bar grill should not find the early C's without some mods to the pins that hold it in place as they are in different places, but the front end of mine has all the holes for both old and new grills. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 7, 2003 dubboy said: But as I belive the front end of mine was set up ready for the changes as the later spec three bar grill should not find the early C's without some mods to the pins that hold it in place as they are in different places, but the front end of mine has all the holes for both old and new grills. That doesn't suprise me at all... I used to work on Beetles (the original ones, not these new re-bodied golfs! :lol: ) and you'd find that hardly any of them left the factory the same as an update approached... Whenever they ran low on bits near to an update, the left them off, used something similar, or used a new bit instead! :shock: :lol: There were plenty of bits that were one year only bits, even complete doors changed from year to year sometimes! :roll: Quote Share this post Link to post Share on other sites
Jimbob1970 0 Posted October 7, 2003 Hey Bally, My 1991 H plate 1.8 16v also has a bulge bonnet! Multi-slat grill though.... more than 3. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 7, 2003 Jimbob1970 Sorry to tell you that your car has almost certainly had it's bonnet replaced at some point... :( VW didn't start making the bulged bonnets that early, and I'm pretty certain that no 1.8 16V left the factory with a bulge bonnet... Quote Share this post Link to post Share on other sites
Majik 0 Posted October 7, 2003 man this is gettin vindictive.....dont argue about what year what was made, if you want later bonnets etc just go and get one! :D Quote Share this post Link to post Share on other sites
G60 0 Posted October 7, 2003 i think its the early bonnet most people are after!! :lol: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 8, 2003 Well just to prove that it takes all sorts, I prefer the later bonnet myself. :) The early one looks too much like a Jetta bonnet... ;) Quote Share this post Link to post Share on other sites
dan 0 Posted October 8, 2003 I prefer the later bonnet as well :) 2p Quote Share this post Link to post Share on other sites
Bally 0 Posted October 8, 2003 Cheers for the replies guys, I did abit of checking lastnite and found that the car was in germany til 1996, then registered in the UK by the 2nd owner who was in the RAF.. would it mean I have a german spec car :? Quote Share this post Link to post Share on other sites
ruffy 0 Posted October 8, 2003 Well if any one wants to swap there late bulge bonnet for a early one i'm up for it.. Andy . Quote Share this post Link to post Share on other sites
Henny 0 Posted October 8, 2003 ruffy said: Well if any one wants to swap there late bulge bonnet for a early one i'm up for it.. Andy . What colour? I quite fancy putting an earlier bonnet on my G60, and seeing as I've got to take it off anyway to get the engine out, seems as good a time as any! :roll: :lol: Quote Share this post Link to post Share on other sites
G60 0 Posted October 8, 2003 if you two have the proper fenders to go with each bonnet, then you'll need to swap those too. when i got my G60 there was a late hood on it with early fenders and there was a slight gap (but annoying to the purist) in the middle between the hood and fender. i planned on getting late fenders... then realized i'd rather have the early hood! Quote Share this post Link to post Share on other sites
ruffy 0 Posted October 8, 2003 Henny said: ruffy said: Well if any one wants to swap there late bulge bonnet for a early one i'm up for it.. Andy . What colour? I quite fancy putting an earlier bonnet on my G60, and seeing as I've got to take it off anyway to get the engine out, seems as good a time as any! :roll: :lol: Okay mate well my cars green and i can see that your cars blue .. but i'm still up for it.. Andy. ****MOD EDIT****.....removed your previous post as it was near identical to this one-vr6storm :wink: Quote Share this post Link to post Share on other sites
Henny 0 Posted October 8, 2003 Sorry Andy, I know that my bonnet needs a bit of a touch up on a couple of small stone chips, but with the engine work I'm doing, I can't justify having the whole bonnet re-sprayed just to put on an earlier one... Thanks for the offer though... 8) Quote Share this post Link to post Share on other sites
dubbprince 0 Posted October 9, 2003 erm...does mine have the newer bulged bonnet or earlier one?? it was first registered on August 1991. Its on a J-plate too...pics can be found in gallery. Quote Share this post Link to post Share on other sites
biggrim 0 Posted October 9, 2003 Just had a look at your oics and it looks like an early one to me mate. 8) Quote Share this post Link to post Share on other sites
