RADO.001
help MOT tomorrow!?
perfect! just when i thought i had it all sort, ready to put through the MOT and finaly start to drive/enjoy my vr again!
went out to double check everythin 2nite befor the test 2mora only to find that the central lockin and electric windows have packed up! have no idea why really, only thing i can think of is changed the battry the other nite as mine was dead.
any help or even ideas to what it could be will be greatfully receved?
Dave
Have you checked the fuse that is on its own above the main bank of fuses?
I lost leccy windows and central locking a bit ago, and for once it was a cheap easy fix, a first on my VR
It won't fail the MOT for this, as long as you can still use the key to operate the door lock, and use the handle to open the door. Both interior and exterior door handles have to work properly though I think.
nice one guys, it was just a fuse. and thank god for that!
my C has more than enough wrong with her to deal with as it is after she crashed and burned the MOT! only put it throught to check if there were any other bits i needed besides a cat (whitch im getin this wk).
heres the list fualts:
* ABS light dose not come on
* nearside headlights out of aim
* offside headlight out of aim
* nearside rear wheel bearin has excessive play
* offside rear tyre depth to low
thats not to bad i hear u say, well it gets worse
* nearside front lower supension arm mounting gone
* offside front lower supension arm mounting gone
* nearside rear brake pipes excessivly corroded
* offside rear brake pipes excessivly corroded
* center brake pipe excexxivly corroded
* exhaust emission too high (witch i knew it would be)
now at this point i thought 'ok, glad i dont have to pay for the schrick till feb now'. then the tester (my dads mate) said 'now then theres a bit on the advisory list'.
and that goes like this:
* nearside rear supension arm mount goin
* offside rear supension arm mount goin
* nearside front brake pipe goin
* offside front brake pipe goin
* offside rear wheel bearing slight play
* center exhaust has minor leak
so all in all A TOTAL PAIN IN THE ASS & WALLET THAT I DONT NEED!
Trigger - look at the list above and you'll soon be smiling! :)
Sorry RADO.001 - thats a fair old list mate. Hope you get it all sorted quickly and cheaply!
rite that fuse at the very top that i changed last time sorted the problem, but now it keeps blowin! any ideas what this could be guys??
you checked it was the right Amp one in the first place? or if anything else has joined/crossed or even crossing the curcit that it is on to over load it?
