markievw 0 Posted December 3, 2006 Hi I own a corrado VR6 that I use only occasionally in the winter. Does anybody have any experience of using these trickle battery chargers that plug into the cigarette lighter? There are some solar powered ones, and one that plug into an electrical socket. Was wondering how effective they were? How do they charge the battery? Do they do any possible damage to the cars electrics? Quote Share this post Link to post Share on other sites
Andy665 0 Posted December 3, 2006 Any of these are spot-on http://www.vertar.com/battery-chargers-conditioners/ I've had an OptiMate for twelve months and its been superb Quote Share this post Link to post Share on other sites
markievw 0 Posted December 3, 2006 hi andy665 cheers for that mate, do they plug into the cigarette lighter. Ideally, like one that does to save opening the bonnet all the time Quote Share this post Link to post Share on other sites
bcstudent 0 Posted December 4, 2006 Probably not, but there is an optional lead you can buy that allows you to place a charging socket anywhere you like on the car. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 4, 2006 There's no reason they can't plug into the cigarette lighter .. Quote Share this post Link to post Share on other sites
craigowl 0 Posted December 4, 2006 With a charger by Airflow UK you do not have to keep opening and shutting the bonnet, thus saving the bonnet release mechanism - another weak point of the Corrado, it would seem. I bought mine a few weeks ago after reading about it on a classic car forum. It allegedly has circuitry which makes the whole set up efficient and safe. You can buy a cigar lighter connection (£10) as I did, but I am not using it. The reason is that, as standard, you are supplied with a lead which can be permanently and securely attached onto the battery. This lead can be fed out from under the closed bonnet and you plug the charger's lead into it. When I take the car out I tuck the battery lead under the bonnet's leading edge. You would have to protect it with a cover tho' if you take car out in the wet. A bit of electrical tape would suffice. Cost including postage was £53.99 (or £10 less if you do not go for cigar lead.) Airflow UK are in Faringdon, Oxon and have a website Quote Share this post Link to post Share on other sites
tonedef 9 Posted December 4, 2006 I bought the Halfrauds trickle charger for £20ish (can't quite remember). Comes with two sets of cables to plug into it, one with crocs, one with ring crimps for a more permanent set up. Not normally impressed by Halfrauds but this time I have to admit they were spot on! Quote Share this post Link to post Share on other sites
