will 2 0 Posted December 23, 2006 what a load of crap to fit, who ever said these take 10mins to fit is a liar, had to drill out the fixing holes to higher the n/s outer, panelbeat behind the 2 inner ones so that they fit without touching the panel,o/s outer was the only one that fitted as it should as for the bulb holders complete mod required to use the o/e holders, grinding off lugs, melting the plastic around the bulb hole so they would just go in then using a soldering iron to make some small groves so that the holder clicks into place just like the o/e does overall time 2 1/2 hours so much for 10mins, in this nice cold weather anyway finished moaning now, they look dam nice lol red and clear crystal by the way Quote Share this post Link to post Share on other sites
moneypit23 0 Posted December 23, 2006 You're not kidding. Mine took ages to fit and admittedly they looked good at first but now there's alga/moss/greenstuff growing in the crystal bits in the corners. Going for all red next. Quote Share this post Link to post Share on other sites
dub envy 0 Posted December 23, 2006 Got mine second hand so all the pissing making holes and stuff was already done. Still fit like arse though. Oh, and they had the moss in them already!! Quote Share this post Link to post Share on other sites
will 2 0 Posted December 23, 2006 these were 2nd hand also and came with the moss but gave them a clean with a tooth brush and they came up ok Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 23, 2006 bead of clear sealant should sort it, still haven't done mine in 18 months though :( Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 23, 2006 still better than oem imo (crap fit though) Quote Share this post Link to post Share on other sites
Phil K 0 Posted December 23, 2006 crap fit yes and mould yes... but to be honest the mould is easy to get rid of - quick jet spray at the right angle sorts it out a treat 8) EDIT: damn my paint looks good in that pic :lol: Quote Share this post Link to post Share on other sites
Jez 0 Posted December 23, 2006 No need to use the original bulb holders in. Just use male spade connectors and slot them into the wiring plug on the car's loom, no need to butcher lights or wiring that way. Quote Share this post Link to post Share on other sites
will 2 0 Posted December 23, 2006 now why didn't i think of that would have saved a lot of time and cold feet :brickwall: Quote Share this post Link to post Share on other sites
RS VR6 0 Posted December 23, 2006 They fit like ass. One side dosen't fit level and the other side isn't flat. I painted the chrome housing...looks a bit better. Quote Share this post Link to post Share on other sites
will 2 0 Posted December 23, 2006 try drilling the holes up so that you can lift the lense up a bit, but watch the bottom hole as there is not much there to drill out, or if you cant drill them use a round file but that will take you a bit longer :thumbleft: Quote Share this post Link to post Share on other sites
Jez 0 Posted December 24, 2006 ajusting the bumpstops on the bootlid helps sometimes too Quote Share this post Link to post Share on other sites
Riley 0 Posted December 24, 2006 Weird :? My inpro's which i bought new needed no modification at all fitting wise :? And i just put spade terminals on the new bulb holders and fed them into the original plugs...Edit:as jez says! They did have the very slight issue of not sitting totally flush though. Neil. Quote Share this post Link to post Share on other sites
B DUB 0 Posted December 30, 2006 You're not kidding. Mine took ages to fit and admittedly they looked good at first but now there's alga/moss/greenstuff growing in the crystal bits in the corners. Mine have gone all manky aswell . :x Quote Share this post Link to post Share on other sites
will 2 0 Posted December 31, 2006 they wount fit flush because the moulding of the rear part is out a couple of mm if you put the oem part and the inpro together you can see the difference bit of a t**t if you want it to look right :x Quote Share this post Link to post Share on other sites
