samwire
Sat in a garage...
ok, hopefully this is in the correct section...
i own a 1990 G reg 16v, which has been sat, motionless in my garage for 2.5 years, and i want to get it back on the road...my first question is, is there anything i need to do before turning the engine and secondly are there any mechanics in the north west (blackburn area) that anyone can recommend...
thanks
sam
Welcome to the forum
2.5 years?
flat battery, perished tyres, the oil will have drained completly back into the sump and could do with a change, check the coolant pipes for leaks, any fuel left in th etank will be well past its best. It wil probably fire ok but with much less punch than before.
Hope that helps, and best of luck.
if it was me i would turn the engine over with a ratchet to make sure its not seized if your lucky it might get a bit of oil to the top end if thats all ok fire her up and straight to a petrol station and a nice drive
How long would it take for an engine to become siezed?
I left mine for about a month and seemed to have some trouble starting it.
Got it going but it went with a bit of a bang..
Fuel will be pish so add some fresh juice. I'd change the oil and filter also be tempted to pull the plugs and drop a little oil in to the cyclinders. And crank it with the ht's off for a min.
I think the typical shelf-life for gas is around eight to ten months if I recall so anything longer than that should probably be replaced.
I have one question too though. Do you guys think I should change my oil right away bearing in mind that mine has sat for six months and it's synthetic with 4000k on it? I just want to take it for a spin and don't see the point in changing the oil until I put it away again.
ok...new battery, fresh juice...started no problem...brakes hadn't siezed...it goes in monday for an mot and a service...
SAMWIRE- theres a VW specialist in DARWEN called Catterals if your struggling. Its near the town centre. I've never used him coz i live in Cardiff now but my mechanic i used when i did live there took his Mk2 Golf Driver (which i sold him) there to have a new heater matrix fitted. Knowing him he wouldn't have used them if they were poo.
ok...as well as a few hoses etc...i need a new radiator fan..is there a generic fan for corrados or does it have to be one specific for the 1.8 16v? and if anyone has one could they let me know please...thanks...
i honestly don't know, but it'd been playing up for some time before, so i guess a replacement is probably for the best, he also can't find my wheel nut thingy...joy!
playing up in what way? if the fan doesnt come on when it should its more likely to be the temperature switch on the rad, try bridging out the connector for the temperature switch and if the fan runs ok you know its the switch.
tbh, i've no idea, but it started not kicking in, the problem is the car is in the garage and i'm miles away at work, and he still can't find the wheel nut and is trying to force it as i type...
ok...work done for mot, parts came to £300, labour about the same...i'm quite pleased..my next question is this, the car has an immobiliser and alarm fitted but no paperwork to say what kind they are, i've been onto vw and they were unable to help...is there anyone who can classify them for me...?
thanks...
Sam (I'm guessing that's your name!)
You can have the alarms re-certified by any good auto-electrician/alarm fitter, if it helps, take a look at the wiring loom. If it's all-black, chances are it's a CAT1, and worth doing, certainly sounds like it is, with it having both.
You might also find a part-number/manufacturer name on the underside of the siren, or on the circuitboard inside the fobs.
Take out the plugs. Spray a rack load of WD40 down the bores. Leave for an hr ot 2 then turn engine by hand. get a socket n wrench on the lower pulley and crank away.
Change the fuel, oil etc as others have said n Check all the tyres etc. It should fire then leave it to warm up. Drop the oil use some flushing oil. Run that then drain and refill with new oil and new filter.
That is def a fun day in my book.
have fun.
ok...got car back today...yay! but at the mo' its running a bit sluggish, i'm hoping that its just the old fuel working its way through the system, so i've topped it up with fresh stuff and some injector cleaner type stuff...oh, and the central locking is playing up..but apart from that my baby's back...
When ya burn that fuel change the fuel filter. then its a clean slate. glad the old machine is running. :D
