CorradoRun 0 Posted February 14, 2007 hi guys, had my 1995 Corrado vr6 on the rolling road on saturday, its all standard with 80k. it only made 175.7 bhp !! so i pluged in the vag com and it showed G28 Engine speed sensor. so i changed that and cleared the code, but the code comes stright back as soon as you drive the car. and its still down on power. any help would be great... Quote Share this post Link to post Share on other sites
vr6storm 0 Posted February 15, 2007 engine speed sensor will always show when you check it on VAG-com as the car isn't running Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 15, 2007 If the Engine Speed Sensor doesn't work, the car doesn't run, plain and simple. There can be borderline cases, but unless your car is stalling or stuttering or failing to start, you do NOT have an engine speed sensor problem. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 15, 2007 G28 is the crank sensor isn't it?? It's the cam sensor, G40 which you cause it to be down on power... What is the actual fault reading as the car would not run without the G28 signal. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 15, 2007 Yep, correct. The cam sensor is the one that loses you 30hp because it retards the ignition right back and runs richer (drops to batch injection instead of sequential). Looks like you've replaced the £140 crank sensor for no reason :-) Quote Share this post Link to post Share on other sites
Crasher 3 Posted February 15, 2007 Can you post the code? Quote Share this post Link to post Share on other sites
martyjmcfly 0 Posted February 15, 2007 Quote Looks like you've replaced the £140 crank sensor for no reason This is what i did. I went on the advise of a local guys cheap diagnostic computer that does 'every' car. Went to amd who's more specific diagnostic read G40 sensor and £28 quid later me very happy. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 16, 2007 Probably not a bad thing though as they have a limited life, so you've bought yourself a bit more peace of mind. Quote Share this post Link to post Share on other sites
