Stan 24v 0 Posted April 4, 2007 She's in at PSI Tuning having some bits done, and Im getting the MOT done at te same time. Had a phone call today saying she'd failed on a bulge in a tyre :mad: and rear bloody brake lines :( Andy has picked her up but not had a chance to look at the problems yet. Anyone have an idea on price for such a job? Are the lines pre shaped or do they need shaping? Quote Share this post Link to post Share on other sites
double-6s 0 Posted April 4, 2007 Thousands mate :) Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 4, 2007 Thousands mate :) Tit!!! :lol: Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 4, 2007 IIRC they're pre-shaped. I think the fitment is reasonably easy, its the bleeding and setting up of the brakes once the jobs complete that might take time and incur cost, I'd not like to guess how much though! Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 4, 2007 built new copper ones for mine when I did the rear axle bushes as they were starting to get really scabby, don't know if the VAG ones would be copper or painted steel like the originals, personally copper seems like the best option, only took my dad a few minutes to make up the lines so it's not that much more work. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 5, 2007 How long/hard is it to bleed the brakes etc? To do the whole job? Quote Share this post Link to post Share on other sites
Goldie 2 Posted April 5, 2007 I thought the lines cam in predetermined lengths as per ETKA and then they are shaped to fit the car.. Its not a difficult job getting the fluid out it just becomes a two man job when filling them up so as to get no air locks.... Quote Share this post Link to post Share on other sites
Jim 1 Posted April 5, 2007 If someone knows what they're doing, and they have good access to the underside of the car, and everything comes off without a fight they should be able to make up two new brake lines and bleed the system in an hour or two tops! I've made up brake lines using a kit and its not that hard to be honest. The difficult bit is scrabbling around under the car, getting covered in brake fluid - which I let 2cc and Tempest do ;) Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 5, 2007 Well I think Andy is suitably qualified, I was just asking out of curiosity as he hasnt had a chance to look at it yet. I think it needs new hoses at the rear too, more bloody money :( Quote Share this post Link to post Share on other sites
Jim 1 Posted April 5, 2007 Time for some Goodridges then mate - fit and forget! GSF is the cheapest place to get them apparently! Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 5, 2007 Its got them on the front already, though the rears had them too, obviously not!! Need to get some prices now. Quote Share this post Link to post Share on other sites
double-6s 0 Posted April 5, 2007 Thousands mate :) Bell end :) :) :) Quote Share this post Link to post Share on other sites
DEL VR6 0 Posted April 6, 2007 mine need doing too. Am about to fit 312's so reckon will get them rear pipes all done at the same time in one hit. Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 6, 2007 I reckon Andy can do that in 2 hours and fit new hoses at the same time. Gavin Quote Share this post Link to post Share on other sites
jonnyboyo 0 Posted April 9, 2007 Had to put new rear brake lines on my valver few months back for the MOT. They cost a chuffing fortune. I'm sure they were £180 in the end, but as they were so goosed the flexi joints break too when trying to remove the brake lines thus adding to the cost. Quote Share this post Link to post Share on other sites
bighairymuppet 0 Posted April 11, 2007 make up your own its cheaper and would only take a bit of time. Just watch out for brake fulid its not nice. Firstly doublecheck whats its failed on, it may not be leaking at all and may have just failed on clips or corrosion /bulges /leaks on the rubber ones. If its clips easily sorted. If its the hoses (gently get them off) and replace them with new ones only £7 a side. Good luck. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 11, 2007 Had the prices back, see below: Hi Stan Please see following prices. Supply and fit Powerflex rear axle bushes £200 + vat Supply one rear wheel bearing - Customer supplied one £8 + vat Set of No. plates £12 + Vat Oil and filter £40 + vat (inc labour) MOT £40 = no VAT on MOTs. Fit Customer's alternator belt - Fit Customer's ABS sensor - Materials for brake pipes and fluid £42 + vat 4x hrs labour for the above work excluding rear axle bushes £140 + vat Total Cost of the above work = £482 + vat (£559.35) Quote Share this post Link to post Share on other sites
jonnyboyo 0 Posted April 12, 2007 Ouch! Things don't half add up. I've just about got over my £550 outlay last October for my mot. :roll: Quote Share this post Link to post Share on other sites
