funboxvr6
Seat Wobble
Hi All
I've just investigated the cause of my passenger seat wobble. It seems that there is a plastic/rubber part missing at the seat travel adjustment assembly.
This probably got lost when the seats where re-furb'd. According to EKTA online this is called a 'Stop buffer' part number 435881203A. Does anyone know if this is correct and if they are available and at what sort of cost? My local stealer's parts dept. is closed now until Tuesday. :x
thanks in advance
hmm, not sure if it will be the same as havent had an issue on my corrado but both my mk2 and mk3 golfs had this problem and the part i replaced sounds like the same part your describing..is it a part that clips onto the bottom corner of the seat where it slides onto the runner??? white piece of plastic??
if so they are super cheap, and GSF sell them!
i bought a few from gsf, however they are easy to break when fitting so grab a couple of spares! as steve said, theyre super cheap!
Buy genuine ones - they don't break and will stay on the seat!
They are also sided (to the seat ie inner and outer) so you need 2 of each...
if you also clean the runners and regrease the seats will slide like new!
Thanks guys. once again I'm amazed at the knowledge out there...
Hope i get the part in time for the MoT & then Le Mans! Anyone else going?
Re: Seat Wobble
Never heard of it. Is that smaller than a Leon?
Nice name for a car.. ;)
