jack 0 Posted June 22, 2007 Can anyone tell me how to remove roof strips Quote Share this post Link to post Share on other sites
timg60 0 Posted June 22, 2007 Pull gently................ Quote Share this post Link to post Share on other sites
sim0n_parker 0 Posted June 24, 2007 mine look abit old, well the strips are ok, but it looks like it should have like a little seal either side? these have perished abit are these avalible? also how much? chears simon Quote Share this post Link to post Share on other sites
Goldie 2 Posted June 24, 2007 They are still available and i must do mine but they are about 40 quid each from the dealers.... Quote Share this post Link to post Share on other sites
daves16v 1 Posted June 24, 2007 Trim off the perished rubber strip with a sharp blade, there a few on here that have done it including me and it looks much better. Quote Share this post Link to post Share on other sites
sim0n_parker 0 Posted June 24, 2007 so if you just trim of the perished part it wont leak water inside? (may be a stupid question haha) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 24, 2007 so if you just trim of the perished part it wont leak water inside? (may be a stupid question haha) they are purely cosmetic btw,you can even remove them completely and you still won't get water in to the cabin from them.........unless you have a dirty big hole in your roof Quote Share this post Link to post Share on other sites
Exup Man 0 Posted June 24, 2007 I was quoted £49.50 each from the stealer's about a month ago. I bought some from GPC at inters the other week for about £35 and they also have the hinge covers for the tailgate. Quote Share this post Link to post Share on other sites
tonedef 9 Posted June 25, 2007 I trimmed the perished bit off mine and they look a whole load better. Still can't get rid of the white staining on the remaining part though no matter how much I try, has anyone had any success cleaning them up? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted June 26, 2007 I trimeed mine and they cleaned up fine, no probs with water either. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted June 26, 2007 I trimmed the perished bit off mine and they look a whole load better. Still can't get rid of the white staining on the remaining part though no matter how much I try, has anyone had any success cleaning them up? Autoglym Bumper stuff (the kind that looks liek green snot).. Works well... But I guess any "Plastic black" stuff should work OK Quote Share this post Link to post Share on other sites
TimVR6 0 Posted June 26, 2007 You could trim off the perished part and run a bead of black silicon down it as long as you're confident with a silicon gun? Quote Share this post Link to post Share on other sites
bruny 0 Posted June 29, 2007 Have just replaced mine [GPC Inters £70] Lift off the rear end first, is snap fit on to a threaded stud, then peel away strip. The front end of the strip is slotted onto a capped locator and needs to be pulled backwards to free it. Removal is easy, refitting new parts is more difficult. I had trouble slotting the front of the new strip under the locator, heat from a hair drier helped but still a struggle. Looks good now though. If GPC try to sell you the 2 extra bits for the hatch you dont need them. Hope this helps ! Quote Share this post Link to post Share on other sites
jack 0 Posted July 1, 2007 Cheers for the advice, I've bought a new set, just wasn't sure if it was a matter of pulling them of, going to give it a go next weekend Quote Share this post Link to post Share on other sites
