Benny16v
60mm drop excessive??
Excessive is when your suspension settings comprimise the handling of the car rather than improve it. On a C I'd say 60mm is about as low as you'd want to go before hitting that point.
On a -60 drop and 15's (Estos) a little harsh but not uncomfortably so.... Mind you your splitter will take a real pounding over speedhumps...
Personally I think it's where the Rado should have sat from the factory as the wheels fill the arches without scrubbing or catching.
At that drop on a 16v your wishbones are above the horizontal point, the bushes and geometry weren't designed for that and a standard car will have better handling.
Mine is lowered to around that level, maybe a shade more and the car is dramaticaly better in all departments, looks and handling, high speed stability.
It is a firmer ride but in a reassuring way as the KWs are excellent...
Worth noting that Goldie's Storm being a late VR is 20mm higher than older cars so 60mm is really 40mm
My TDI is 50mm and it's deffo too low for comfort, G60 still looks a little high at 30mm so I reckon 35-40 is perfect
Nope mine are pretty much horizontal, if not slightly below... And handles just fine... TBH you'll only notice any difference right at the limit anyway..
mine 30-35mm perfect to drive but could be lower for looks just at the front
new one 50-60mm and is too low, ride is ok but splitter has worn down to a knife edge
Totally depends on your suspension choice and what you're after.
My vr is lowered 70+mm and i never really had any problems with that - apart from the odd splitter issue :)
My suspension is rock hard so the lack of travel means rubbing etc is minimised.
I imagine my wishbones are at a ridiculous angle, but the car handles excellently and is incredibly stable.
You'll most likely notice it in the form of bump-steer. The suspension geometry isn't correct, so going over a bump will tug the steering wheel to one side, depending on which side of the car hits the bump.
I agree with Dinkus, it might not be noticeable unless driving hard but I suffer from bump steer due to my car being set low (I've no idea how much by). I knew that I was going to be trading some handling for looks and accepted that.
I guess it's a case of finding a healthy balance between what you find acceptable for handling/looks. Try a few different options out and see how you get on.
also if u use brand new lowering springs, it will sit at a height for a while untill the springs "settel" so bare this in mind when you lower as after a few weeks it will sit a tad more lower (prob nothing noticable by the eye)
Im lookin to lower the rado 60mm on 15's (until i get some Borbet A's)
is this excessive?
You wouldn't ask the question if you didn't want us to say "YES"! ;)
Just do it and see what you think mate. If it sucks bring it up a bit :)
My car, lowered 70+mm, definately suffered from the odd bout of bump steer as discussed above. But I'm wierd, and I quite liked it! At the end of the day you are the only person who knows what you like. I reckon the majority of the folk on here would have hated my rado for being too hardcore for the road, but I absolutely loved it.
Suck it and see dude :)
Im all for an uncomfortably hard ride so i think it will be ok lol,
i dont think it will handle any worse than it does now to be honest it feels like a 4x4 compared to my old mk2 which was on its ass!!
