mistrall 0 Posted December 14, 2007 hi guys , every time i put in my 15amp fuze into the slot , when i turn the key it blows streight away. any common probs that cause this ? it was working fine 2 days ago. many thanks, mistrall Quote Share this post Link to post Share on other sites
Crasher 3 Posted December 14, 2007 So this is fuse 5 then? Disconnect the wiper motor and see if the fuse still blows. Quote Share this post Link to post Share on other sites
mistrall 0 Posted December 14, 2007 okys ill try that :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 14, 2007 i found the wiper motor is pretty vunerable to wet and stuff especially if you have a nice waxed bonnet and its been rained on, you lift bonnet and it dumps all the water straight onto the motor and its wires Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 18, 2007 You have a short to earth in the cct mate. Stick a multimeter on ohms at the fuse, with power off, and the other end to earth. You will get 0 ohms, or thereabouts. Disconnect the wiper motor and see if it goes o/c, if so then the fault is more than likely in the motor itself, if it doesnt then the fault is between the fuse and motor. Quote Share this post Link to post Share on other sites
mistrall 0 Posted December 21, 2007 i disconected the wiper motor and the fuzs nolonger blows , i have a spare motor and was wondering if there easy to change ? im unable to drive till i fix this so any advice welcome. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 21, 2007 Never changed one on a C but have done on a 200sx, and the worst thing was the access, and would assume it'd be pretty much the same on any car to be honest. Only way to find out is have a go mate, you cant drive it anyway. Quote Share this post Link to post Share on other sites
mistrall 0 Posted December 22, 2007 ok ill get my spanner lol wish me luck. Quote Share this post Link to post Share on other sites
mistrall 0 Posted December 22, 2007 nope , i have no idea what to do with this :( tryed to undoo everything on my old c to get the motor off but its not going to move :( Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 22, 2007 i took a motor off and it was quite easy from what i remember, i removed the whole mechanism 1st am sure it was just two bolts or allen keys things to undo Quote Share this post Link to post Share on other sites
