andycowuk 0 Posted November 18, 2003 Hi My stealer cant locate a part number for a bolt on etka, can anyone help? The bolt I need is one of the 3 which go down into the rear engine mount, but this one also has a threaded shaft coming out the top to hold the braket for the connector block for the lamda probe (and temp sender on later cars) I can get a pic showing the broken one if needed but you should see it easily if you look at yours. thanks Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 18, 2003 N90553202 - 82 pence. They bend and break quite easily. Kev Quote Share this post Link to post Share on other sites
Henny 0 Posted November 18, 2003 yup, I broke mine while taking the engine out... :? bit of a naff design if you ask me... :roll: Quote Share this post Link to post Share on other sites
andycowuk 0 Posted November 19, 2003 cheers! Howcome you knew it so quick? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 19, 2003 Cause I replaced it in October! I looked on the invoice for ya :lol: Kev Quote Share this post Link to post Share on other sites
andycowuk 0 Posted November 25, 2003 Kev, the one you rewcomended was a 17mm head, the one I need had a 13mm head. Any ideas? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 25, 2003 Hmmm, not sure in that case. They found it in EKTA no problem when I called them to order mine. AFAIK, the main thread that goes into the engine has a 17mm head and the smaller thread that secures the 02 sensor plug plate is a 13mm head. Are we talking about the same bolt? Mine's the one that drops through the mount from the top, behind the engine block. Kev Quote Share this post Link to post Share on other sites
andycowuk 0 Posted November 25, 2003 maybe they picked the wrong part at the factory......I need the 13mm one that goes down vertically into the mount. there are 3 x 13mm bolt, one of these holds the o2 sensor. Quote Share this post Link to post Share on other sites
Banana Man 0 Posted November 25, 2003 Andy the bolt you need by looks of it is N 019 504 2 it's an M8 bolt which is a 13mm headed hex Quote Share this post Link to post Share on other sites
