quicky1980 0 Posted December 30, 2007 Im needing to change my gearbox, and Im also wanting to do a 4wd conversion. So are there any gearboxes suitable for a vr6 that will allow for the conversion at a future date? Will I need to lock the out put shaft to the rear?? Saves me having to remove the gearbox numerous times. Which cars had them and how much are they generally? Thanks Quote Share this post Link to post Share on other sites
MK1Campaign 0 Posted December 30, 2007 There was a Golf 3 VR6 Syncro in Germany. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted December 30, 2007 anything a bit closer to home? or is germany the only option? also, if I used a g60 4wd box what what be the problems? Quote Share this post Link to post Share on other sites
VR6Will 0 Posted December 31, 2007 anything a bit closer to home? or is germany the only option? also, if I used a g60 4wd box what what be the problems? the g60 4wd box wont physically fit to the vr6 engine, you need either a vr6 syncro gearbox or 02m from a r32 Quote Share this post Link to post Share on other sites
quicky1980 0 Posted December 31, 2007 ok cool, now can I use the vr6's drive shafts? will the r32 gearbox suit the vr's torque output? Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 3, 2008 Anyone know if their are different types of r32 gearbox and is a straight swap for a vr6 box? thinking about this box as its 6 gears too. im guessing its not Quote Share this post Link to post Share on other sites
12 DEG BEN 0 Posted January 3, 2008 Read on here that the vr shafts wont work with 02m gearboxes. Also you have to figure out a gearbox mount as 02m has none at the back. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 3, 2008 Speak to PhatVR6 on E38 Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted January 4, 2008 Spotted this http://www.pistonheads.co.uk/sales/311784.htm Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 4, 2008 i think i missed out on a bargain. on ebay a r32 box went for slightly over £100. maybe it wasnt an 02m. if it was, damn!!! any idea how the shafts have to be changed? and what needs to be done to make a gearbox mount? I can get it done but want to know whats involved so can judge time it will take to do the work. is there a link to a how to..? Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted January 25, 2008 Speak to PhatVR6 on E38 He actualy has a 6sp 02M box for sale just now http://www.edition38.com/forums/index.php?showtopic=130798 Quote Share this post Link to post Share on other sites
corradosyncro 0 Posted January 29, 2008 hi R32 02m 6speed , flywheel, clutch, starter, slave line, shifter & cables off of 24v r32 maybe audi tt 3.2 but not checked Modified front mount Custom axles 24V 02m slave cylinder line (you can't just connect your existing slave line to the o2m.) Flywheel to crank and clutch bolts (24v o2m) Don't forget to get the harness/plugs for gearbox speed sensor and reverse light i can get the drive shafts made for you custom you would need o2m inner cvs and your vr6 outs can be used but i would replace with new for peace of mind im getting 2 sets of front shafts price at the moment if i was to add another set maybe cheaper i can also supply the o2m gearbox mount , i do have a front gearbox mount that i can take some pics of and you can copy are you wanting to run 4wd eg r32 setup ? or do front then do rear later as i have some parts to help with this eg beam,syncro floor etc you could run gearbox on its own without prop etc i no some one who did this for 2 mths with out probs http://www.corradosyncro.co.uk Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 29, 2008 cheers corradosyncro. Ive put plans on hold as I need to use the car daily for now. What Im thinking of doing is getting all the parts together and do the conversion done over a weekend. The major hold up are the gearbox mounts, I would need to copy someones, or get one done. If you could find out the price of adjusted shafts that would be good. Just to make sure, this is for a vr6 conversion. Quote Share this post Link to post Share on other sites
corradosyncro 0 Posted January 29, 2008 no worries i have mounts that you can copy etc are you wanting to use 6speed r32 box for future 4wd conversion or just a fwd box 6speed does not make huge different just the drivers shaft will be shorter forgot to mention the down pipe will need some magic doing to it etc thanks paul Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 29, 2008 have you got any pics of the box installed, would like to see how much change i need to do for the mounts. I work in the engineering trade so shouldnt be too hard to copy yours and the shafts. May even look into making a kit for other rado lovers. Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 29, 2008 There's a thread on doing this on Vortex somewhere, but can't remember the link. It looks like you need to move the mounting point about 3" back on the crossmember in order to clear the output shafts. You then use a dutchdub or similar L-shape bracket to bolt the 'box to. Quote Share this post Link to post Share on other sites
corradosyncro 0 Posted January 30, 2008 i have a 02m with mounts on in the garage will take some pics this weekend vortex link http://forums.vwvortex.com/zerothread?id=2633108 Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 30, 2008 cheers for the link. some how I dont think Ill be doing it easily over a weekend. I suppose if I built up the mount on a spare subframe then its posssible as a weekend job. Quote Share this post Link to post Share on other sites
andyvlw 0 Posted March 20, 2008 corradosyncro I've got a R32 engine which came along with a DSG box, which I intend installing in my VR. As I don't have all the DSG bits, I've decided to use a manual 02m box, I don't have the driveshafts, did you get new ones fabricated if so who off and how much were they, or did you use the original R32 shafts and get them re-machined. Also unsure if I'm going to go 4WD or stick with the 2WD at present. Andy Quote Share this post Link to post Share on other sites
pandreson 0 Posted September 29, 2008 Moab, Utah is the Mecca of the 4WD world with over 30 trails to choose from, most within a short drive from town. These trails cover some of the most rugged and scenic country you will find anywhere. ------------------------------------------------------ pandreson Used Cars Quote Share this post Link to post Share on other sites
ADZ_VR6 0 Posted September 29, 2008 Intresting reading this id love 4whl drive ive always had in the back of my mind but dont no if ill ever get that involved, well not at the mo Quote Share this post Link to post Share on other sites
