Chris Langdon
compression testing figureS on VR6
hi
i hoping to do a compression test on my VR tonight (borrowed mates compression tester) i was just wondering what sort of figure(s) i should be expecting from a good VR engine??? as i dont know, also i fitted the centre dials ages ago but dont know what sort of pressure a good VR engine should be at idle when at working temp?
any help and info i would be most gratful
regards
Chris L
Are these figures barg (gauge pressure)i.e. above atmospheric, or absolute pressure?
Best wishes
RB
No idea, its what my draper compression gauage said on the dial
Best wishes
RB
I've got the same Draper gauge - the pressure readings are relative (ie. in addition to atmospheric pressure), the minimum reading is 0 bar, which is what you get when it is 'zeroed'! :wink:
The other useful thing to check is the variation between cylinders, if there is more than 3 bar difference between any of the cylinders, you have a major problem... :( My variance was about 1/3 bar 8)
im guessin you lot disconnected the injectors/fuel rail before carrying out the test, to stop lots of fuel being throw down the bores!!!
and is it best to do it hot as for the working tolerances
total agree with the above checking the difference between them
cheers
Chris
cheers
Chris
yeah remove the bottom right relay and fuse 18 and disconnect the LV side of the coil. Make sure your battery is charged!
Hope you allay your fears Chris and there isn't a problem with it, that's a nice car you have and I'm really looking forward to seeing it this year.
i guess the last one dont apply to me cos ive got a coil pack?
Undo the LV side of the coil pack then! lol I theres a similar LV (low voltage) plug on it, i.e. not one of the spark plug leads the little lead.
Basically you don't want the coils generating a high voltage as it wont be used - this could damage the coil pack/coil or earth through you while you are messing in the area giving you a shock.
And just check with your book that fuse 18 is the fuel pump and the bottom right relay is the fuel pump relay, if my memory serves me right it is.
Its a good idea to:
    first take the fuel pump relay / fuse out
    start the car a couple of time with the plugs in it will briefly run using up fuel left in the lines.
    disconnect the LV side of the coil / coilpack
    whip all the plugs out
    screw your gauge in
    turn car over on starter until its not going up anymore (I did it 7 times to be sure)
    reset the gauge and take 3 readings for each cylinder and average them
if the readings are all within the range 11-13 bar then all is well. If a cylinder reads much lower than that somethings amiss. In this case repeat the above compression test but squirt a bit of oil down the cylinder this will temporarily seal the rings. If the reading is unchanged then you have a head gasket / cylinder head issue, if the reading is in the normal range or above then you have a piston ring / bore wear issue.
If 2 adjacent cyclinders are low then the head gasket may have gone between them.
Right here are my figures that i got from doing a compression test today. The Car cover 70000 Miles regularly service, me personally that looks like ok figures, would just like soone elses view.
Still NOT at the bottom of my oil consumption and sightly carboned no:6 Spark plug?????? Its starting to do my head in!!!
HOT
Cyl.1 160IB/11bar
Cyl.2 160IB/11bar
Cyl.3 160IB/11bar
Cyl.4 160IB/11bar
Cyl.5 155IB/11bar
Cyl.6 170IB/11bar
WET TEST
Cyl.1 180IB/12bar
Cyl.2 180IB/12bar
Cyl.3 160IB/11bar
Cyl.4 165IB/11bar
cyl.5 190IB/ 13bar
Cyl.6 165IB/11bar
Cheers mate :D
Those figures are fine.
When you were cranking the motor over, did you notice if one or more cylinders took much longer to stop the gauge than the other cylinders?
Is that Asim's old car? If it is I doubt it has anything seriously wrong as it was the most powerful standard VR6 Stealth have seen. 212hp!
no cheesewire, its not asim's, i brought it about a year ago in Bournemouth, the owner before me had it for about five years and looked after it,
christ 212hp i take it that is at the flywheel????
what should a standard VR be at the wheels?
Where is stealth i have heard of them, i fancy going to that rolling road day in april but im in Devon!!!!! :D
Why do you ask mate? what would that indicate????
I'm guessing that if one cylinder took longer than the others, it might have a poor seal - not enough to loose significant pressure, but it wouldn't get the gauge up to the final reading as fast as the other cyls, no?
